Doing def/dpf delete tomorrow - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 20 Unread 11-16-2018, 03:56 PM Thread Starter
I bought a Livewire TS+ and 4" mbrp dp back straight pipe exhaust. I'm not a licenced mechanic, but feel confident I can do this myself. Couple questions. Do I install the tuner first, or exhaust? Should I cap off the fuel/def lines that attach to the dpf, or what do I do with them? What should I do with the sensors after I disconnect them? Any and all help is appreciated! 2015 F250 Lariat 6.7L
Derek Danebrock is offline
post #2 of 20 Unread 11-16-2018, 06:22 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 558 Post(s)
Feedback Score: 11 reviews
Tune first to make sure it takes.
Sensors depend on tune/exhaust
No fuel lines.
Def take will drain out...
HeavyAssault likes this.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #3 of 20 Unread 11-17-2018, 02:33 AM
Quoted: 192 Post(s)
Def will not drain out. Nothing comes out of that line unless the pump is on.
I always pack the connectors with grease and then wrap them in electrical tape and zip tie them to the frame.
SOOTIE is offline
post #4 of 20 Unread 11-17-2018, 06:59 AM
Pigman12's Avatar
Quoted: 3 Post(s)
I'm the op, just made a proper profile. The main reason I'm doing the delete is because the def tank heater crapped out. Should I or can I drain the tank some how?
Pigman12 is offline
post #5 of 20 Unread 11-17-2018, 07:01 AM
Pigman12's Avatar
Quoted: 3 Post(s)
Anyone know much about these tuners? I would like to keep it on stock tune, but I need it for the deletes. Is this possible?
Pigman12 is offline
post #6 of 20 Unread 11-17-2018, 07:23 AM
Pigman12's Avatar
Quoted: 3 Post(s)
I just read something saying that the Livewire TS+ does not do deletes? Is this true? I bought it as a kit with the exhaust labelled def/dpf delete kit
Pigman12 is offline
post #7 of 20 Unread 11-17-2018, 11:18 AM
Quoted: 192 Post(s)
Depends what part number it is.
SOOTIE is offline
post #8 of 20 Unread 11-17-2018, 11:58 AM
Pigman12's Avatar
Quoted: 3 Post(s)
5015pc is the part number
Pigman12 is offline
post #9 of 20 Unread 11-17-2018, 12:54 PM
Quoted: 192 Post(s)
You are good to go then
SOOTIE is offline
post #10 of 20 Unread 11-17-2018, 01:02 PM
Pigman12's Avatar
Quoted: 3 Post(s)
Awesome, thanks SOOTIE
Pigman12 is offline
