Looking to level my truck, which style - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 28 Old 07-08-2018, 07:58 AM Thread Starter
sierracharlie338's Avatar
Quoted: 71 Post(s)
Garage
I need a little guidance on what type of leveling kit to run. I have a 2105 F250 4x4 CCSB that I want to level and eventually run 35s on aftermarket wheels but that will be down the road a ways. Ill be running factory rims and 295s for a while. Below is a pic of the back blocks that came on the truck. My main goal is to keep the factory ride or improve it.
I was originally looking at a Ready lift spacer system with the extender brackets but think I may want to upgrade my shocks so was looking at a shock/spring lift. I am not looking to spend 1500-god knows what on a leveling kit, I just can't afford it. Id like to keep it around 600 for the parts and I will most likely install it.
Thoughts on any specific lifts or one type (spacer vs shock/spring) versus the other? Thanks in advance.
Stephen
15 F250 CCSB Lariat 4WD
Previous:
99 F250 SCLB 4WD
sierracharlie338 is offline
post #2 of 28 Old 07-08-2018, 11:27 AM
ULM2008's Avatar
Quoted: 6 Post(s)
Stephen
Your going to want a track bar drop bracket or track bar too. and a good track bar is almost your whole budget. Problem is, you want to spend cheap, your going to receive cheap and you won't get a equal or better ride improvement. IMO its not good to go cheap on a vehicle suspension. unfortunalty people who go with those spacers and nothing else end up having all kinds of issues with drivability. as expected. Otherwise I guess id suggest spacers, alignment cams and a track bar drop bracket. I think you have to do new shocks too or shock extenders to make up for the lift if im not mistaken.
ULM2008 is offline
post #3 of 28 Old 07-08-2018, 11:29 AM
ULM2008's Avatar
Quoted: 6 Post(s)
Will need a 350 or 4" block as well depending on a 2" and 2.5" front leveling
ULM2008 is offline
post #4 of 28 Old 07-08-2018, 12:28 PM Thread Starter
Quoted: 71 Post(s)
Garage
That is what I was gathering from my research but unable to find it in plain print anywhere. If I want to do a 2.5 up front I’ll have to add 4 inch blocks in the back to keep from having a backwards rake.
Let me clarify that I am not a cheap person when it comes to most things. I was hoping to be able to level the truck without spending an arm and a leg but I WILL NOT sacrifice ride quality or drivability for a cheap lift.
Back to the drawing board for me it seems. I feel I already know the answer but what 2-2.5inch lift is recommend the most?
Previous:
99 F250 SCLB 4WD
post #5 of 28 Old 07-08-2018, 12:30 PM Thread Starter
Quoted: 71 Post(s)
Garage
And thoughts on something like the ReadyLift kits (all the spacers, track bar drop brackets, etc)
Previous:
99 F250 SCLB 4WD
post #6 of 28 Old 07-08-2018, 12:31 PM
voodooridr's Avatar
Quoted: 956 Post(s)
I needed to add a 1" block to the 2" factory block to get my '04 to sit level after doing 2.5" front leveling springs
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
post #7 of 28 Old 07-08-2018, 12:50 PM Thread Starter
Quoted: 71 Post(s)
Garage
Which leveling kit did you go with?
Previous:
99 F250 SCLB 4WD
post #8 of 28 Old 07-08-2018, 12:59 PM
voodooridr's Avatar
Quoted: 956 Post(s)
Mines an '04 so it's got front leaf springs, i believe they were ProComp springs
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
post #9 of 28 Old 07-08-2018, 01:16 PM Thread Starter
Quoted: 71 Post(s)
Garage
Looks good!
Previous:
99 F250 SCLB 4WD
post #10 of 28 Old 07-08-2018, 02:55 PM
JHTX's Avatar
Quoted: 33 Post(s)
Looks good!
Think somebody on here or army had an Icon kit up for grabs.
Sent from my iPhone using Tapatalk
JHTX is offline
