Delete, but still have quiet exhaust? - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 31 Old 04-15-2018, 12:15 PM Thread Starter
Quoted: 2 Post(s)
I'd like to eventually go through the delete process, but don't want the extra exhaust noise. I would like it to stay at the stock level, or as close as possible. Back in the day, I had a Magnaflow muffler on a grand prix that was designed more like a resonator, but was thicker and quieter. Has anyone replaced their DPF with a resonator or straight flow muffler? How has that affected noise levels? I don't have any plans to throw a super aggressive tune on, so max power gains aren't my goal. I just want to remove points of failure and reap the power bonus that comes with it...after the power train warranty expires.
cody6766 is offline
post #2 of 31 Old 04-15-2018, 12:48 PM
ZCherry27's Avatar
Quoted: 51 Post(s)
I just did a delete pipe and from inside the cab itís not noticeably louder unless windows are down
HeavyAssault and riotrob like this.
2003 CC SB 6.0 with a MBRP 4inch straight pipe,
with QT Tunes, PowerMax turbo, BPD 58v FICM, lifted 4inches with BDS, 20in Fuel hostages wrapped with 35in Nitto Trails -Sold
2014 CC SB 6.7 weight reduction kit installed
with GH tunes 20x12 Gear Big Blocks 305/50 nitto 420s
ZCherry27 is offline
post #3 of 31 Old 04-15-2018, 01:50 PM
lowmpg's Avatar
Quoted: 112 Post(s)
Personally, I've noticed that different tunes create different exhaust notes. Tyrant is definitely more quiet/calm, Gearheads tend to be more blow-dryer like...I run a Tyrant tune with a 4" straight pipe and the cabin isn't noticeably louder.
HeavyAssault and IYAO6502 like this.
The Resurrection
lowmpg is offline
post #4 of 31 Old 04-15-2018, 01:51 PM
Drunk Post Extraordinair
Old King Coal's Avatar
Quoted: 231 Post(s)
Garage
I agree with ZCherry, I don't think it's really any louder since it was deleted.
However, your definition of quiet and mine may differ.
I think a lot of guys around here use a Donaldson muffler for the "stock quiet" sound. Seems like a 52" is what they have, but I can't say for sure. There should be some threads around here somewhere.
So strong is Tradition that later generations will dream of what they have never seen.
Old King Coal is offline
post #5 of 31 Old 04-15-2018, 02:18 PM
DiggerDerrik's Avatar
Quoted: 65 Post(s)
After 9 months of being deleted I got sick how loud the truck was outside of the cab. I agree with the above posts and in cab the delete doesn’t add much exhaust sound (turbo sound it adds a bunch). So I added a cheap high flow muffler to the delete pipe. Pretty much back to stock now.
AP Exhaust XS2772 Muffler https://www.amazon.com/dp/B004A5L9PG..._3b80Ab4JPCY83
HeavyAssault likes this.
2011 F350 CC SRW
DiggerDerrik is offline
post #6 of 31 Old 04-19-2018, 10:01 PM Thread Starter
Quoted: 2 Post(s)
Thanks for the info so far, guys. I'd like to see it quieted down to as close to stock levels (most importantly) in and (less importantly) out of the cab. I know that's a challenge when cutting off parts that are designed for quiet operation from the factory, but it's a goal and not exactly an expectation.
Has anyone seen the need to add multiple mufflers/resonators in place of the DPF to really quiet things down, or does a single one do the trick? I'm after really quiet for two reasons. The simple one is that I like a quiet cab. After owning louder cars in my younger years, I want a quiet DD. My T/A that I drive on nice days gives me my loud car fix. Also, I'm a bit of an audiophile, and plan on installing a sound quality-oriented stereo and want as little exhaust interference as possible.
Thanks again!
cody6766 is offline
post #7 of 31 Old 04-20-2018, 03:41 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 906 Post(s)
Feedback Score: 3 reviews
I've found my Nitto EXO tires make more "cab noise" than my thru pipe deleted system. Using just a DPF delete pipe on the OEM back section is cheap and works. If you want different DPF back piping try any of the suggested resonators.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #8 of 31 Old 04-20-2018, 04:00 AM
Quoted: 36 Post(s)
Replaced the DPF with 4" Flo-Pro straight pipe, left everything else stock and not much of a difference in sound, using Tyrant Tunes.
rcg270 is offline
post #9 of 31 Old 04-20-2018, 05:26 AM
Quoted: 45 Post(s)
Garage
Like it was said further up, everyone has a different opinion on what is loud. My truck has 5" straight pipe and Tyrant tunes and I notice the turbo more than the exhaust note. Granted, years of sirens and air horns may have my hearing slightly off, but it's extremely quiet when compared to my straight piped cummins.
2012 F-250 Supercrew - Pro-Comp 6" - 22x12 Hostile Sprocket's - 37" Toyo R/T's - AFE Elite Intake - 5" Diamond Eye Exhaust - SCT X4 & Tyrant Tunes - Sinister EGR Delete
Previously- 2006 Ram 2500, 5" turbo back, Crazy Larry tuned, fried injector harness, 6 toasted injectors, and one melted transmission.....
My "Other Rides"
2015 Pierce Velocity Industrial Pumper
2013 F-550 Haz-Mat/Rescue
jpw_07 is offline
post #10 of 31 Old 04-20-2018, 06:22 AM
Quoted: 65 Post(s)
Even before I added the muffler all I heard in the cab was the diesel sound the engine makes, the turbo and the hum of the tires. Maybe I’d hear the exhaust if there was a bus or some other large vehicle on the passenger side to echo off of.
2011 F350 CC SRW
