Stock EGT sensor for EGR Delete - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 21 Old 09-21-2017, 08:40 AM Thread Starter
blackseven's Avatar
Quoted: 13 Post(s)
I'm using Torque Pro to monitor my EGT's... Do I need to move the EGT11 probe to the where the EGR temp probe was in order to continue monitoring EGT's there with torque pro? Sort of confused, which PID I should monitor?
blackseven is offline
post #2 of 21 Old 09-22-2017, 05:02 AM
MagnoliaTom's Avatar
Quoted: 38 Post(s)
Garage
I'm interested to hear some feedback as well. I'm in the same boat and am about to lose some weight on the truck
Sent from my iPhone using Tapatalk
2014 F350 Platinum DRW 6.7
2006 F350 Lariat DRW 6.0 PSD sold
2005 F250 Lariat 6.0 PSD sold
2004 Excursion Limited 4wd 6.0 PSD sold
2016 Jayco NorthPoint 377RLBH
2014 Coachmen Freedom Express 320BHDS Liberty Ed. Sold
2000 Excursion Limited 2wd 7.3 PSD Sold
MagnoliaTom is offline
post #3 of 21 Old 09-22-2017, 08:54 AM
Quoted: 31 Post(s)
I cannot take credit for the below; given to me by another user on another forum. Use one of the 4 EGT probes from the exhaust in the EGR block off plate and plug into the EGRT11 harness plug that was on the probe in the EGR before removal. I was confused and rerouted my EGT lines from the the exhaust all the way back up to the block off plate; this was a major pain and did not work. Using the EGR temp sensor harness, and a EGT probe from the exhaust, and the formula below worked. It was also super simple as the EGR temp sensor harness is right by the EGR block off plate (which should have a hole for an EGT probe).
"I used EGRT11 which is real handy to the block off plate.
I then came up with a custom equation for Torque Pro to convert the volts read by the sensor to temperature. I haven't been able to compare the output of Torque to a known calibrated sensor but it does seem to be in the right ballpark.
PID: 22055E
MIN 0
MAX 2000
scale x1
Unit C
(0.0004*(((1164.26*(((256*A)+B)*0.00097285))/(4.98-(((256*A)+B)*0.00097285)))*((1164.26*(((256*A)+B)* 0.00097285))/(4.98-(((256*A)+B)*0.00097285)))))+(1.107*((1164.26*(((2 56*A)+B)*0.00097285))/(4.98-(((256*A)+B)*0.00097285))))-237.33 "
MagnoliaTom likes this.
andrewtac is offline
The Following 2 Users Say Thank You to andrewtac For This Useful Post:
blackseven (09-23-2017), MagnoliaTom (09-22-2017)
post #4 of 21 Old 09-22-2017, 09:50 AM
Quoted: 38 Post(s)
Garage
Thanks Andrew!
post #5 of 21 Old 09-22-2017, 09:54 AM
Quoted: 38 Post(s)
Garage
Quick question...
Once this is set up, what is the normal temp range and is the "alarm" temp 1250?
post #6 of 21 Old 09-23-2017, 07:21 PM Thread Starter
blackseven's Avatar
Quoted: 13 Post(s)
Just wanted to follow up and say that this did work for me using torque pro. I have EGT's now!
post #7 of 21 Old 09-24-2017, 06:25 AM
Quoted: 38 Post(s)
Garage
What temps are you seeing driving on the highway?
post #8 of 21 Old 09-24-2017, 06:57 AM Thread Starter
blackseven's Avatar
Quoted: 13 Post(s)
5-700 cruise and peak of 1050 under wot. I have the gearhead tow tune with the same lag that everyone else seems to complain about. Going to go with the tyrant tune instead.
The Following User Says Thank You to blackseven For This Useful Post:
MagnoliaTom (09-24-2017)
post #9 of 21 Old 09-24-2017, 07:44 AM
Quoted: 38 Post(s)
Garage
Thanks! I'm collecting all my parts now and will be doing mine shortly. I planned on getting Tyrant tunes, so I'm glad I won't buy tunes twice
post #10 of 21 Old 09-24-2017, 08:16 AM Thread Starter
blackseven's Avatar
Quoted: 13 Post(s)
Lesson learned there. Should've done my research first.
