Stock EGT sensor for EGR Delete - Page 2 - Ford Powerstroke Diesel Forum
 3Likes
post #11 of 21 Old 01-30-2018, 11:32 AM
Hayhook's Avatar
Quoted: 57 Post(s)
Originally Posted by andrewtac View Post
PID: 22055E
MIN 0
MAX 2000
scale x1
Unit C
(0.0004*(((1164.26*(((256*A)+B)*0.00097285))/(4.98-(((256*A)+B)*0.00097285)))*((1164.26*(((256*A)+B)* 0.00097285))/(4.98-(((256*A)+B)*0.00097285)))))+(1.107*((1164.26*(((2 56*A)+B)*0.00097285))/(4.98-(((256*A)+B)*0.00097285))))-237.33 "
So, it says "Unit C" which is Celsius, right? does the reading come across in Fahrenheit or Celsius?
Hayhook is offline
post #12 of 21 Old 01-30-2018, 01:28 PM
Quoted: 31 Post(s)
I believe it is degrees F. The temps are in line with previous temps from pre delete.
andrewtac is offline
post #13 of 21 Old 02-02-2018, 10:09 AM
Quoted: 29 Post(s)
I cannot take credit for the below; given to me by another user on another forum. Use one of the 4 EGT probes from the exhaust in the EGR block off plate and plug into the EGRT11 harness plug that was on the probe in the EGR before removal. I was confused and rerouted my EGT lines from the the exhaust all the way back up to the block off plate; this was a major pain and did not work. Using the EGR temp sensor harness, and a EGT probe from the exhaust, and the formula below worked. It was also super simple as the EGR temp sensor harness is right by the EGR block off plate (which should have a hole for an EGT probe).
"I used EGRT11 which is real handy to the block off plate.
I then came up with a custom equation for Torque Pro to convert the volts read by the sensor to temperature. I haven't been able to compare the output of Torque to a known calibrated sensor but it does seem to be in the right ballpark.
PID: 22055E
MIN 0
MAX 2000
scale x1
Unit C
Andrew,
Just downloaded Torque Pro. Under settings>Manage extra PIDS/SENSORS>add custom PID, then under Equation, do I input exactly what you have with all the numbers and symbols?
When I do it it, comes up with an error mismatched parentheses.
rcg270 is offline
post #14 of 21 Old 02-02-2018, 10:10 AM
Quoted: 31 Post(s)
Check the parentheses
post #15 of 21 Old 02-02-2018, 01:18 PM
Hayhook's Avatar
Quoted: 57 Post(s)
To confirm, even though the input says C the readout is in Fahrenheit degrees.
Sent from my iPhone using Tapatalk
Hayhook is offline
post #16 of 21 Old 12-28-2018, 06:34 AM
Hoping to resurrect this thread. I'm trying to read the temp sensor at the manifold pre turbo.
When I add the Custom equation to torque pro it says 237.33 " does not exist...... any ideas?
cdorsey50stang is offline
post #17 of 21 Old 02-11-2019, 12:32 PM
cmunsell's Avatar
Quoted: 3 Post(s)
I will double up on the resurrection hopes.
My truck is a 2013 on a diet with block off plates.
I am using my iPhone so unable to have Torque Pro. Anyone know if OBD Fusion will get me the same result?
I have downloaded that app and there is a Ford specific PID that says Exhaust Gas Recirculation Temperature Sensor C (Bank 1, Sensor 2)
I have also tried to enter the manual formula above and keep getting a 'No Data Received' message.
Anyone have any experience with this app? Do I need to swap out the temp sensor that was in the EGR pipe with one from the DPF in order to get a reading? Right now I am using the probe that was in the EGR crossover pipe.
Would love to be able to figure this out to avoid buying a separate probe/monitor.
cmunsell is offline
post #18 of 21 Old 02-11-2019, 03:51 PM
G8orFord's Avatar
Quoted: 2517 Post(s)
Garage
The one you're looking for is EGRTA not EGRTC. I'm not sure if the 2013 has EGRTC or not, but I'm pretty sure the one you're referencing is "A". You may want to try Forscan, I'm pretty sure they have an iOS version. It's a bit of a different animal compared to TP or OBD Fusion, but about as complete as you can get.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #19 of 21 Old 02-12-2019, 05:04 AM
I got Torque pro to work on reading that sensor. Its the one at the bottom of the pic. "EGT EGR"
post #20 of 21 Old 02-12-2019, 05:25 AM
cmunsell's Avatar
Quoted: 3 Post(s)
I will keep trying. I reset the app and reconnected last night, I was getting a reading from the EGRTC Sensor but it was jumping all over the place and returning values that did not make much sense to me. For instance, at idle it was showing 400-500. However when I began accelerating at a normal pace it would spike to 1,800 and then drop to 32 back and forth and in between. Did not pass the sniff test.
I am wondering if using the stock EGR probe rather than one from the DPF is throwing it off.
Will keep trying to get the formula to work but in the meantime all suggestions greatly appreciated!
cmunsell is offline
