No Limit Catch Can -- It's no Joke - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 18 Old 08-04-2017, 02:13 PM Thread Starter
Quoted: 25 Post(s)
Received my CCV Re-Route kit and Catch can from No-Limit.. That s!#t is some High Quality H2O Dang catch-can is almost 3 lbs.. See attached pics..
ID:	639826   Click image for larger version
ID:	639834   Click image for larger version
ID:	639842   Click image for larger version
HeavyAssault and MagnoliaTom like this.
2015 F-250 Powerstroke FX4
"Archoil GangBanger Member"
BeerEngineer is offline
post #2 of 18 Old 08-09-2017, 08:01 PM
Quoted: 2 Post(s)
That is one fine looking can!
sevobuck is offline
post #3 of 18 Old 09-24-2017, 07:27 AM
MagnoliaTom's Avatar
Quoted: 38 Post(s)
Garage
How does this set up work? Does it vent to the atmosphere or is it going back into the intake as "filtered" air
Sent from my iPhone using Tapatalk
2014 F350 Platinum DRW 6.7
2006 F350 Lariat DRW 6.0 PSD sold
2005 F250 Lariat 6.0 PSD sold
2004 Excursion Limited 4wd 6.0 PSD sold
2016 Jayco NorthPoint 377RLBH
2014 Coachmen Freedom Express 320BHDS Liberty Ed. Sold
2000 Excursion Limited 2wd 7.3 PSD Sold
MagnoliaTom is offline
post #4 of 18 Old 09-24-2017, 08:14 AM Thread Starter
Quoted: 25 Post(s)
I vent to my exhaust from the Catch Can... No Limit also sells a venturi for this setup - Weled into my exhaust from the Can - and it provides the low pressure vacuum as the intake would... Also helps burn off any steam / vapor ... It's a great setup - no issues at all... Very rarely, and only at idle do I see just a little steam coming out of the exhaust pipe... I drain the catch can every 2-3 weeks - might get a spoonful or 2 of oil.... I also purchased the baffle as part of the CCV Re-Route too - believe that helps get the oil level down as well... Below is a couple of pics of the Venturi into exhaust...
ID:	649402   Click image for larger version
MagnoliaTom likes this.
The Following User Says Thank You to BeerEngineer For This Useful Post:
MagnoliaTom (09-24-2017)
post #5 of 18 Old 09-26-2017, 04:52 PM
Quoted: 22 Post(s)
do you have any pics of mounted can? I want one just can't picture it with titan and dieselsite filter on frame
BIGJUICE is offline
post #6 of 18 Old 09-26-2017, 08:08 PM
Quoted: 2 Post(s)
I would like to see some pics of the catch can mounted as well. I know it can be mounted anywhere but it seems like there should be an ideal location. I called No Limit and they were almost no help at all. The guy on the phone had never installed one and kept having to go ask his "associate" every question I asked him. I love their products but wish the directions were a little more specific. Once I get my put on (next week I should have time) I'll get some pics posted.
sevobuck is offline
post #7 of 18 Old 09-27-2017, 05:43 AM
Heavy_GD's Avatar
Quoted: 3125 Post(s)
Garage
Feedback Score: 4 reviews
@BeerEngineer tighten up!
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #8 of 18 Old 09-27-2017, 06:36 AM Thread Starter
Quoted: 25 Post(s)
Mine is mounted on the passenger side - you will have no clearance issues there.. Pics attached below.. Decided to mount there because of it's proximity to the exhaust... The red hose comes from the motor, because I installed the NO Limit CCV baffle it was easier to run the hose across the top of the motor instead of running on driver side - then around the bell housing...
ID:	650185   Click image for larger version
ID:	650193   Click image for larger version
ID:	650201   Click image for larger version
MagnoliaTom and Timbo_Slice like this.
post #9 of 18 Old 10-02-2017, 01:18 PM
Loud Exhaust Aficionado
Timbo_Slice's Avatar
Quoted: 62 Post(s)
Garage
Sweet ride man. About your MPD piping kit...how much improvement in performance have you noticed?
'15 F350 6.7L Super Crew Cab 4wd, 37 13.50 R20 Nitto Trail Grapplers on 20x12 TIS 535b -44 offset
Front - PMF 4-link 6 inch lift
Rear - PMF 2.5 Lift from Rear Shackle Hanger Flip Kit
- No name 5" rear block
Baja Customs Tracinator tracbar
AMDP pass through egr plate
AMDP Billet aluminum Y pipe intake
SCT TS+ Livewire
Full EGR, DPF, CCV delete
5" MBRP downpipe back straight pipe
Rigid D2 fog lights, 20" Opt7 light bar
Mag-Hytech high capacity lower oil pan
Mag-Hytech high capacity transmission pan
Redhead Steering Gear Box, Helwig sway bars
Eventually I'll get around to the JL Audio 13w2 install
Timbo_Slice is offline
The Following 2 Users Say Thank You to Timbo_Slice For This Useful Post:
BeerEngineer (10-02-2017)
post #10 of 18 Old 10-02-2017, 05:10 PM Thread Starter
Quoted: 25 Post(s)
Thanks Timbo_Slice... I am really happy with the performance - the piping kit along with the NL IC, certainly improved spool time , definitely feels more responsive and quicker.. It does feel like it has more power - but really can't give you an honest answer how much... With the right tune setting, with the foot on it - it is hard to get the EGTs above 1200.. Cruising EGTs are about the same as I had previously before the NL IC and Piping Kit...
When I say the right tune setting, with my SOTF, I have found the tune setting 3 ( +100 HP) gives me the lowest EGTs at the higher RPM bands... If I switch to level 4 or 5 - the EGTs will climb to 1350 + .... Which makes me believe that this setup is begging for a better Turbo, than the Stock '15 VGT turbo...
Sooo, a better Turbo and possibly one of those SunCoast Diesel Transmission kits are in my future....
The best part to me - is I can now hear the Turbo Hated it prior , having a diesel and not hearing the turbo ....
