Busted Bolts on EGR Long Pipe - Page 2 - Ford Powerstroke Diesel Forum
 15Likes
post #11 of 55 Old 03-27-2017, 10:58 AM
Barry Smith's Avatar
Quoted: 10 Post(s)
They say "tighten hardware" because they know 15 min. after you start it they will be welded in place!
kaya likes this.
2014 F-250 6.7 4X4 Crew Cab Black Lariat Black Leather 20"Wheels EZ Lynk PPEI S&B intake. Firestone Air bags, 34 gal. Aux fuel tank. Andersen Ultimate Hitch.
Barry Smith is offline
post #12 of 55 Old 03-27-2017, 12:21 PM
Quoted: 695 Post(s)
Originally Posted by Doctorsmack03 View Post
Kaya-
Would you recommend using any thread locker, etc or just straight bolt torque? Anybody know what lb/ft to torque these bolts to? The instructions say "tighten the hardware." No kidding!
oh yea slather them in never seize compound.
they're probably about 8-10ft/lbs maybe. not sure exactly. nothing crazy. just a good snugging.
edit: just checked and they're 89 in/lb, then 45 degrees.
so probably in the area of 10 ft/lb.
a good snugging
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
post #13 of 55 Old 03-27-2017, 07:03 PM Thread Starter
Quoted: 2 Post(s)
I was able to tap about 5 clean threads into the ugly hole. I installed the factory bolts back in place with the gasket and torqued to 15lb/ft. I kind of wanted to over torque them just in case they weren't very well tapped. I figured it would be better to strip them now while it was all apart, but since everything seemed to hold okay, I'm not too concerned. I will definitely be checking it weekly for the next few months just in case. So I finished cleaning up wires and reinstalling the manifolds, air intake and the exhaust.
All in all, this wasn't a terrible project but there were definitely times that I stepped away to beat the punching bag. I would say that the lesson here is be patient and methodical. Do not just follow the basic BS directions that the deletsters provide. It is amazing how simply they put everything. There is no mention of PB blaster or remove the bolts while hot, etc. Just a 1-25 listing of steps like "remove bolts," "drain radiator" or "reinstall Intake components." No torque ratings for any of the parts, just tighten.
Thanks for the help and just listening. Venting frustrations is always a good thing.
Barry Smith and kaya like this.
1997 Crew Cab Long Bed Black 4wd Powerstroke F350, 2005 Axles, 6" Icon Lift, 3 Link, Fox Reservoir Shocks, 35" Toyo Muds, Tymar Intake, MBRP 4" Straight Through Exhaust, DP Tuner
Doctorsmack03 is offline
post #14 of 55 Old 04-02-2017, 09:34 PM
DIGMAR's Avatar
Quoted: 28 Post(s)
1000% THIS.
I've had my delete plates on for the last 50K+ miles and have pulled those bolts numerous times and they slide right out now. but like we said before, crack 'em loose on a hot motor and lay on the PB Blaster
2012 F250 Lariat CCSB SRW:
H&S XRT w/ Gearheads tunes, Edge CTS, 5" FLO PRO DP Back w/ Muffler
S&B CAI, EGR Block Off Plates, No Limit CCV
Retro HIDs, ProComp 2.5" Stage3, Carli Track Bar, BDS Radius Arms, Fox 2.0 IFPs
DIGMAR is offline
post #15 of 55 Old 08-08-2017, 04:21 AM
Quoted: 7 Post(s)
I have two broken bolts now.. my plan of action is different than everyone else I've read about. I'm going to weld new bolts to the flange and just put some nuts on it and call it a day. Why bother drilling or welding and trying to unbolt the nut. A mobile welder will come weld this for about $100 and I'll be on the road within an hour of starting.
Anyone see why this wouldnt work? I'm basically turning the bolt holes into studs. I'd weld it myself but we just moved and I don't have 220 in the garage yet..
If the flange is cast iron I might be boned here.. however, a professional welder might be able to make this work. If I were doing it myself I would just keep adding layers to the existing bolt until I had enough to weld the new threaded section on. So I'd avoid welding to the iron if I could.
MightyMouse75 is offline
post #16 of 55 Old 08-08-2017, 08:58 AM
Quoted: 695 Post(s)
Yes that's a very good idea! Use 8mm studs instead of 6mm (like they should have done in the first place).
Unfortunately, it is cast iron tho.
Let us know how this works out!
Did you run the vehicle for a few minutes just prior to get the manifold hot? That is paramount. And don't take them all the way out hot. Just a couple turns, then spray the hell out of them with a good penetrant. Let it cool while you work on the rest of removal. Have never had an issue with this method. And I've probably dinner somewhere between 50-100 coolers. Maybe more lol. Don't really keep track
bcamos likes this.
-Michelangelo
kaya is offline
post #17 of 55 Old 08-08-2017, 11:25 AM
Quoted: 19 Post(s)
Garage
I'm so glad I found this thread and this post specifically. I'm tackling this same project Friday morning and I've got somewhere to be on Saturday morning with a trailer. I'm impatient, so I don't want to wait until Saturday afternoon lol. I started on the PB Blaster yesterday morning, so I'm hoping that it's fairly smooth.
bcamos is offline
post #18 of 55 Old 08-08-2017, 12:16 PM
Quoted: 10 Post(s)
Not everyone has problems. I'm happy to report my removal was way easier than expected. I sprayed with PB blaster a couple of times the week prior. Before I even warmed the motor up I figured I'd just test them a little and see if they would budge. A little pressure and they were loose, spun them out by hand.
Hopeless Diamond is offline
post #19 of 55 Old 08-08-2017, 12:18 PM
Quoted: 19 Post(s)
Garage
What year and how many miles?
Mine is 2013 with 100k miles. I'm not expecting this to go too easy for me.
bcamos is offline
post #20 of 55 Old 08-08-2017, 12:39 PM
Quoted: 10 Post(s)
Forgot to add that, 2012 - ~87k
Plan for the worst, hope for the best and be surprised
