Delete Help Broke Bolt!!! - Page 2 - Ford Powerstroke Diesel Forum
 4Likes
LinkBack Thread Tools
Old 03-07-2017, 08:29 PM Thread Starter
Yes the EGR cooler is still on. I am only installing the block off plates. I did have anti-seize on the bolts as I was putting them back in. I was reusing the old bolts which is my fault and should have known better and was using the swivel due to the plastic upper intake. I am sure the bolt will back right out as it was going back in and has anti-seize on it I just don't have the tools here to do it. I am taking it to the shop around the corner from my house tomorrow anyway for another issue so while it is there I am just going to have them take it out. I have since ordered an extractor kit so I have it. I was at fault I knew better so I guess I will chalk this up to a learning experience and pay the price. I am still glad I did most of the work myself and it went relatively easy until I made the mistake. Thanks for all the suggestions they have helped a great deal.
2011 F250
EZ-Lynk
GDP Tunes
S&B Intake
EGR Delete
DPF Delete
emt676 is offline
Old 03-13-2017, 07:25 AM
Quoted: 32 Post(s)
all the advice on here is pretty solid. I recommend you don't try and ez out. Just keep slowly drilling it out and using a small punch tap out the piece and vacuum or shop air to remove. Don't worry you didn't make a mistake, I would say 1 in 4 of those bolts break off like yours did. I happened to me. 3 drill bits later I managed to knock was was left of the old bolt and re tap the threads. That plate doesn't need another of torque so use new bolts and I would remove the EGR cooler at this point to give you more access. It's not must more work.
skycrane is offline
Old 03-13-2017, 07:45 AM
Durapig Eater's Avatar
Quoted: 163 Post(s)
It broke going in not coming out. Besides I think he took it in.
The wrong was not using new bolts.
The 2 in the manifold break all the time. If it breaks coming out then an easy out would probably break off too. That's why you stop if it feels springy at all.
Ford master tech told me that he heats the manifold with a brazing tip, if they don't come out then it's easy out, if that breaks then it gets a new manifold. When new goes in its dripping with never-seize. Never reuse the bolts. Just tight with a 1/4" ratchet or box wrench.
Durapig Eater is offline
Old 03-30-2017, 05:55 PM Thread Starter
I did get it drilled out and everything is up and running. Yes my mistake was using the old bolts. Thanks for all your replies.
2011 F250
EZ-Lynk
GDP Tunes
S&B Intake
EGR Delete
DPF Delete
emt676 is offline
Old 03-30-2017, 08:53 PM
Quoted: 4 Post(s)
Glaad to hear you got it all taken care of. I threw on an Icon front 2.5" lift today with a BD diesel track bar and man am I happy its done.
16PS250 is offline
Old 04-02-2017, 09:47 PM
DIGMAR's Avatar
Quoted: 28 Post(s)
[QUOTE=Durapig Eater;14704257] You break that off in your hole, it's gonna take a drill bit from NASA to get that mother out. QUOTE]
SERIOUSLY... No one wanted to touch that one!!!??? I'll be the 5 year old LOL...
2012 F250 Lariat CCSB SRW:
H&S XRT w/ Gearheads tunes, Edge CTS, 5" FLO PRO DP Back w/ Muffler
S&B CAI, EGR Block Off Plates, No Limit CCV
Retro HIDs, ProComp 2.5" Stage3, Carli Track Bar, BDS Radius Arms, Fox 2.0 IFPs
DIGMAR is offline
Old 12-13-2017, 03:28 PM
brettwingfield's Avatar
Quoted: 11 Post(s)
Garage
[quote=DIGMAR;14792714]
I SO appreciate another 5 yo besides me on this forum! Thanks for the laugh out loud belly laugh.
Brett Wingfield
2015 Crew Cab Lariat
6" BDS Four Link
Fox Shocks
Fox Dual Steering Stabilizer
AMP Power Steps
22" Helo Rims
37" Open Country R/T
No Limit EGR Block off Plates
Flo Pro 4" Race Pipe
brettwingfield is offline
Old 10-18-2019, 09:33 AM
T-G
What size are these bolts? I just had a PO42E code come up and if I cant figure out what the problem is looks like I may have to make this a off road race truck so I want to be ready for anything that may have when I start taking it apart
T-G is offline
Old 10-19-2019, 04:20 PM
I had them break off and Im pretty sure the hole is a 6mm x 1.00 pitch. I ended up removing the upper and lower intake and just drilled and tapped with 1/4 x 20 and bought new bolts.
Sent from my iPhone using Tapatalk
Creekrat82 is offline
