OK To Just Block EGR? - Ford Powerstroke Diesel Forum
 10Likes
post #1 of 13 Old 11-16-2016, 07:51 AM Thread Starter
tho2nd's Avatar
Purchased a No Limit delete kit, but wondering if I can just block the EGR for the time being versus complete removal? (I'm sure this has been addressed, but I wasn't able to find it)
Thanks,
TH
2014 Lariat CCSB, PSD. H&S Mini-Maxx, Diamond Eye 5" straight pipe, Recon Cab Lights, Recon Mirror Lights, 2.5" Pro Comp Leveling kit, 1" blocks in rear, 35x12.50 Nitto Trail Grapplers on 20" Fuel Octane Wheels, Color-Matched trim and front bumper, baked and painted headlights, SD Tailgate/Front Trim Lettering, 8'6" Fisher X-Treme V snow plowc
tho2nd is offline
post #2 of 13 Old 11-16-2016, 07:59 AM
Extruding Elements
FLOstroked's Avatar
Quoted: 70 Post(s)
Thanks,
TH
I'm looking for this exact answer but as a "forever" solution vs "in the mean time".
2015 F-250 Super Duty 6.7l
Purchased 10.14.16 15k miles
*I 3D design/print things*
FLOstroked is offline
post #3 of 13 Old 11-16-2016, 08:02 AM Thread Starter
tho2nd's Avatar
I plan to eventually do a full delete, but I guess I'd like to run it a while prior to doing so. Don't ask me why.....I suppose to ensure that I'm happy with tunes and new exhaust.
Sticky F250 likes this.
tho2nd is offline
post #4 of 13 Old 11-16-2016, 09:19 AM
whitesavage46's Avatar
Quoted: 13 Post(s)
There is essentially no difference in the block off kit vs. the full delete kit, If you ever plan on running a aftermarket intake it would be in your best interest to go with the FULL delete so that you can get the stock coolant lines out of the way and have enough room for the intake to go in without being a PITA. But i have seen some accomplish an aftermarket intake with just block off kit but the coolant lines are a ***** to work around and make fit.
tho2nd likes this.
whitesavage46 is offline
The Following 2 Users Say Thank You to whitesavage46 For This Useful Post:
Mossive (11-18-2016)
post #5 of 13 Old 11-18-2016, 08:39 AM
Quoted: 22 Post(s)
Garage
seems like a simple mod based off the instructions on their website. 100 bucks for two plates tho....
Mossive is offline
post #6 of 13 Old 11-18-2016, 10:15 AM
Sticky F250's Avatar
Quoted: 8 Post(s)
I exchanged my No Limit Full Delete Kit for the NL Block Off kit and I am just waiting for the parts to arrive so I can install... At this point in time, the block off kit is the easier solution for me. If further down the road I decide to delete, so be it and I'll cross the bridge when I get there!
tho2nd likes this.
2012 Ford F-250 LARIAT w/ FX4
6.7L Powerstroke Diesel
Diesel Site Fuel Filter/Water Separator
SCT X4 with tunes from Tyrant Diesel
5" SS Flo-Pro Exhaust
Donaldson Muffler
No Limit EGR Block-Off
Roof Clearance Lights
Sticky F250 is offline
The Following User Says Thank You to Sticky F250 For This Useful Post:
tho2nd (11-19-2016)
post #7 of 13 Old 11-18-2016, 11:33 AM
Quoted: 10 Post(s)
Good call, this is the route I went as well. I may have to put mine back on someday if I have any major issues. The way I see it the only thing you gain doing a full removal is a little extra room under the hood and you shave 15 or 20 pounds on a >8000# truck. Seems like a lot of hassel for nothing. I would think it would last forever with the blockers installed as it is just a coolant passage at that point. Also the coolant line with the bent metal section I removed and ran a piece of heater hose and routed it under my nl stg2. It is not at all in the way for the intake. This is on a 15 thou, I think the coolant lines may be slightly different on the 2nd gen 6.7
tho2nd and Sticky F250 like this.
2015 f350 lariat ultimate
5" Flo pro
Egr blocker plates
Ndash sotf
Nl stage 2 intake
cappa is offline
post #8 of 13 Old 11-18-2016, 12:04 PM
bogeyman's Avatar
Quoted: 9 Post(s)
Garage
If I just run a block off - without the addition of a programmer/tuner, am I going to get any benefit (or see any codes)?
bogeyman is offline
post #9 of 13 Old 11-18-2016, 01:28 PM
riotrob's Avatar
Quoted: 26 Post(s)
Send a message via Skype™ to riotrob
Good to know. I am looking into the same though process of doing the block off as a permeant solution. Good question and I am glad you asked...this will help me...
tho2nd likes this.
riotrob is offline
post #10 of 13 Old 11-18-2016, 07:39 PM
Quoted: 10 Post(s)
You need to tune it. Do not block off the egr unless you are removing the dpf and tuning the truck. You will have problems.
5" Flo pro
Egr blocker plates
Ndash sotf
Nl stage 2 intake
cappa is offline
