Snorkel Intake - Page 2 - Ford Powerstroke Diesel Forum
 3Likes
post #11 of 17 Old 07-05-2016, 05:23 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 871 Post(s)
Feedback Score: 3 reviews
I'd double pre-wrap a NoLimit before I'd add a snorkel.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #12 of 17 Old 07-05-2016, 05:41 PM
ZMANN's Avatar
Quoted: 3949 Post(s)
And then the Ram boys are stacking Snorkles LOL
Rattlesnake18 likes this.
6.0 flush pdf
ZMANN is offline
post #13 of 17 Old 07-05-2016, 06:19 PM
AMERICA!
Rattlesnake18's Avatar
Quoted: 1739 Post(s)
Feedback Score: 6 reviews
A snorkel on each side... BRILLIANT!!
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #14 of 17 Old 07-06-2016, 08:48 AM Thread Starter
mattastic13's Avatar
Quoted: 16 Post(s)
I figured that would be the response.
I'll get a Prefilter from NoLimit.
However, I still like the look of the AEV. BTW, they have no plans to focus on other brands. Just Jeeps and Rams.
2012 F250 King Ranch 4x4
Ready Lift 1.5" level kit front/Custom 1" block rear/Fox 2.0s/Nitto Trail Graps 295/65/R20 on stock King Ranch rims No Limit delete pipe with Gearhead tunes on a SCTx4, EGR block off plates
No Limit Stage 2 Intake
Sweet Gipsy Danger Sticker
mattastic13 is offline
post #15 of 17 Old 07-06-2016, 09:04 AM
Shadowfax's Avatar
Quoted: 37 Post(s)
They can't drive in the water anyway look at the sank thread. You'd have to replace every connection and computer if you went anywhere deep enough to need a snorkel.
2015 f350 lariat
2003 Jetta TDI 5spd
Shadowfax is offline
post #16 of 17 Old 07-06-2016, 09:45 AM Thread Starter
Quoted: 16 Post(s)
LOL...I was more looking to put it higher than the dust on the oilfield locations I work at and leave my truck idling at. Not interested in putting my truck in water, I have a CJ7 for that.
post #17 of 17 Old 08-05-2016, 07:57 PM
You will only lose performance and mileage with a snorkel.
Iirc, it's been proven before on other vehicles.
Higher than the dust on your location?
All my peterbilts have intake levels higher than your snorkel would be, as do all my frac, cement, and acid pumps and we still have to shake the dust out of the filters at least once a week or two or the filter minders kick in.
I check the filter on my 450 about once a month and knock the dust off. It idles most of the time. The minder isn't usually past the first line, occasionally it is, but you're not going the help anything, dust wise, with a snorkel. You're better off having a water hauler do dust control than cut holes in your truck.
Goindownhole is offline
