EGR delete - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 24 Old 10-04-2015, 10:51 AM Thread Starter
Quoted: 15 Post(s)
Originally Posted by chadjones99 View Post
I did a EGR delete , left it in.. why not leave it in. I just installed block off plates, one plate had a EGT probe hole, I bought the probe at Rudys , hooks to my SCT livewire
only too a hour to do and block off plates 65 $ ? probe I forget but cheap
maybe a hour and that's with running the wire to the gauge and etc
Because there is still a chance of it leaking coolant to the engine from the cooler is there not??
Gonetfx is offline
post #12 of 24 Old 10-04-2015, 02:53 PM
DIGMAR's Avatar
Quoted: 28 Post(s)
When you use the block off plates, the only thing changing is that the exhaust does not flow into/through the egr. Coolant will still circulate as it normally does, just eliminated the exhaust which would just get stopped up at the EGR valve. When deleted the valve is disabled and remains closed, if you don't do the block offs or full delete, after a while that valve will get caked in soot and refer it useless if you ever try to go back to stock.
2012 F250 Lariat CCSB SRW:
H&S XRT w/ Gearheads tunes, Edge CTS, 5" FLO PRO DP Back w/ Muffler
S&B CAI, EGR Block Off Plates, No Limit CCV
Retro HIDs, ProComp 2.5" Stage3, Carli Track Bar, BDS Radius Arms, Fox 2.0 IFPs
DIGMAR is offline
post #13 of 24 Old 10-04-2015, 03:32 PM
Quoted: 337 Post(s)
I was quoted 5-6 hour job @ $95 an hour and $250 for parts but I know the guy that owns the shop.
HLBeef is offline
post #14 of 24 Old 10-04-2015, 07:51 PM
DIGMAR's Avatar
Quoted: 28 Post(s)
5-6 hrs for an EGR delete is outrageous. Like we,be stated above, 3 maybe 4 hrs max... And that's from people who are not actual mechanics. I'd expect a reputable shop to be able to do a full delete much faster, cleaner, and more efficient than the average joe, drinking beer in his garage (me) playing with his truck in the spare time. Just my $.02
DIGMAR is offline
post #15 of 24 Old 04-14-2016, 02:02 PM Thread Starter
Quoted: 15 Post(s)
In the shop now getting it done I bought all the parts needed for the job to lower the shop cost was qouted $1000 CAD if everything went smoothly I sprayed the bolts down the day before let it sit overnight hoping that come out nicely for them they didn't look too bad but I have 132xxx kms on it. So buying the parts myself I saved from the original qoute $400 approx living up north sucks sometimes but the scenery is nice
Sent from my iPhone using Tapatalk
Gonetfx is offline
post #16 of 24 Old 04-18-2016, 04:52 AM
Quoted: 34 Post(s)
I left the EGR, but unplugged the EGR
gunman41mag is offline
post #17 of 24 Old 04-18-2016, 08:30 PM Thread Starter
Quoted: 15 Post(s)
Yes as did I all winter but I hear the valves can fail and be forced open from the exhaust pressure. I know you can buy block off plates which is cheaper than the full egr delete to prevent that from happening but I also read somewhere of it failing and getting coolant into the engine? I didn't want to risk it so jus decided to pull it out completely. Towing season is here so wanted it done before hand
Gonetfx is offline
post #18 of 24 Old 04-19-2016, 05:46 AM
Quoted: 34 Post(s)
Asked my mechanic how much he would charge me to remove the EGR & DEF tank, he said $170, sounds good to me, i'll be looking for a EGR delete kit
post #19 of 24 Old 04-19-2016, 06:55 AM
TX_TRU_STUD's Avatar
Quoted: 58 Post(s)
Can you clean the valve with water and de-greaser like you can the EGR inner core?
TX_TRU_STUD is offline
post #20 of 24 Old 04-19-2016, 08:15 AM Thread Starter
Quoted: 15 Post(s)
How and where? Lol the delete kit alone was $230 or 240 CAD I went with the sinister diesel one also I forgot to mention they also installed the egt probe and sensor docking station too the docking station was like $250 as well maybe less.
Gonetfx is offline
