6.7L Surge! - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 4 Old 08-24-2019, 01:23 PM Thread Starter
Exclamation 6.7L Surge!
2011 6.7L F350 Crew/Dually/4x4 with 78K. Engine has surged three time is the last two days; twice when shifting from P to D, and once when just stopped at a light in D. One of these events the RPM went to 3900; had to hold two feet on the brake to keep it stopped. Pretty scary!
Any suggestions?!
(Somehow related? Found big time corrosion on one battery terminal last week. Cleaned it, but I suspect I need to have the negative cable replaced?)
Thanks!
tgrichards is offline
post #2 of 4 Old 08-25-2019, 11:50 AM Thread Starter
OK, I'm replying to my own post: No replies or comment or suggestions? Can I be the FIRST and ONLY person who's had this experience?
Comment please!
post #3 of 4 Old 08-25-2019, 02:18 PM
Quoted: 115 Post(s)
Looks like you found a similar thread, did you do what the thread said to do?
https://www.powerstroke.org/forum/6-...dle-surge.html
The Resurrection
lowmpg is offline
post #4 of 4 Old 11-13-2019, 06:30 PM
Lightning546's Avatar
Quoted: 15 Post(s)
Garage
Thanks!
The problem is that you can't just simply replace one negative battery cable on these trucks, you have to replace the entire harness.
Instead of running single cables to the starter and to the multiple fuse panels in the vehicle, they put the cables for both batteries going to the starter/fuse panels and made them into a separate harness, it costs $285, that does not include installation.
I had to replace both batteries in my 2016 F-350, CC, DRW, 6.7L, King Ranch, FX4 last month because the passenger side battery had an acid leak from the positive post, it almost destroyed that battery cable in the process. The harness is most likely still on backorder, but, you'll have to call your local Ford dealer to find out for sure.
T-1 Certified
Independent Amsoil Dealer
Over 20 years of experience with the Amsoil product line.
Lightning546 is offline
