2012 P0331 and P0332 - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 1 Old 07-20-2019, 11:11 AM Thread Starter
Thanks all for the add to the site. Had a 2006 and needed the help fro 4 sites to keep that project happy but the new 2012 6.7 has been a dream. 8 years and 88k mileage I needed to change out a couple of glow plugs, had an oil/ coolant drip and a turbo noise but it’s been an absolute beauty.
Well until now... got the dreaded CEL light and simple check.... P0331. Cool. Simple part swap... knock sensor bank 2? No real drivability limitations gets up and goes with no load 5k no load no problem. Seemed a bit underpowered when I towed 12k but didn’t have much to compare to as the route and load was different from my 5th wheel. Drove unloaded 300 miles and the CEL went away on trip home. Only thing that makes my hairs stand up is I bought a couple of def refills 4 months ago after I got a 100 miles to empty notification. I filled 2.5 gallons and the computer said 500 miles to empty so drive thinking it wouldn’t take the second fully. Went to put the second in and the product was opened? Truck took another gallon and computer said full?
Could a bad gallon of def give me a gas motor CEL? Where do you start with bad info?
Thank you all in advance.
Phartlov is offline
