Valve cover removal - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
 1Likes
  • 1 Post By Larry1013
post #1 of 5 Old 08-24-2018, 09:39 PM Thread Starter
Valve cover removal
Hey guys, new to forum but haven’t seen any real info on what I’m in deep with. I have a 2011 Powerstroke with 78k miles. I experienced the injector clamp failure and shot cylinder #3 injector out of the cylinder head. While changing the injector, I accidentally dropped the copper washer into the valve train. Now, being somewhat of a perfectionist, I have to retrieve it to ensure it will not cause a problem. I can’t seem to find any good information on how to remove the valve cover. I have removed all of the bolts, and it feels as though the top is still bolted down. I have been able to wiggle the bottom of the cover up about 1/4”. For reference I am talking about the passenger side valve cover.
Thank you guys
Matt Lemons is offline
post #2 of 5 Old 08-25-2018, 09:01 AM
Quoted: 105 Post(s)
I sent you a private message with my email address. send me an email and I will send you copy you can print out of how to remove the driver's side/left hand valve cover.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is online now
post #3 of 5 Old 01-18-2020, 06:58 PM
Hey there, can you send me the same copy? Literally same issue on the passenger side, except it’s with injector number two. Trying to find videos on youtube and all over the place but no one seems to have filmed it. 2011 with 220k.
post #4 of 5 Old 01-19-2020, 02:24 AM
Quoted: 105 Post(s)
Passenger side/RH 6.7 valve cover removal.
jman37 likes this.
Larry
post #5 of 5 Old 01-21-2020, 11:44 PM
Thank you!
