2011 6.7 glowplugs caused engine failure - Page 4 - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
 5Likes
post #31 of 37 Old 03-28-2017, 01:07 PM
SixFive's Avatar
Quoted: 43 Post(s)
Garage
Thumbs up
Originally Posted by chopped30 View Post
The root cause of my problem was exhaust valve which in turn damaged the glow plug and finally the turbo. I agree that the number of vehicles effected are low compared to production numbers and there is not a real way of knowing if you will have this problem. Like I posted before, most times this problem occurs is low miles. Not all the time but most mechanics I have talked to say the ones they have replaced engines had 30K miles or less. With a brand new Ford crate motor I am not going to worry... I gotta warranty with it!
Thanks that makes sense. I'm pretty sure since mine has 112k miles it's good and broke in.
2011 F250 Crew Cab 4x4 6.7 Lariat
SixFive is offline
post #32 of 37 Old 05-30-2017, 07:27 AM
Quoted: 8 Post(s)
So I'm up to 130k on mine -but this is the first I've heard of this issue. I just got a quote from the dealership for changing out the glowplugs and it came in just under $1000. Generally you guys dont think its cause for concern since mines "well" broken in?
mark
msk182 is offline
post #33 of 37 Old 05-31-2017, 06:39 AM
SixFive's Avatar
Quoted: 43 Post(s)
Garage
mark
Glow plugs are less than $100 for 8 new ones online and the process doesn't seem all that complicated.
Maybe check out some Youtube videos, you may be able to do it yourself?
I might end up doing the same just to be safe.
SixFive is offline
post #34 of 37 Old 10-28-2017, 05:47 AM
Casey Bones's Avatar
Quoted: 16 Post(s)
I plan on doing this myself and I just answered my own question in another thread about this issue... Just have to make sure you buy the right plugs for your truck for your year..
https://www.amazon.com/gp/product/B0...3MZDUPQK5KQJHZ
Mudrun08 likes this.
2011 F350 6.7L FX4
MODS: Little Trees New Car Smell Air Freshner
Casey Bones is offline
post #35 of 37 Old 10-28-2017, 07:44 AM
Quoted: 133 Post(s)
Didnt the tsb and previous posts indicate that the valve was the issue not the glowplugs?
Ross
2006 f-250 CCSB king ranch diesel 4x4. Stock w/ air bags, rancho 9000s, and coolant filter.
Rossterman is offline
post #36 of 37 Old 10-28-2017, 07:52 AM
Quoted: 17 Post(s)
Valves failed and caused a collision with the glow plugs which shattered.
Ford fixed it with a 2 prong attack...
1.) Better QC with the valves
2.) Moved the glow plugs farther out of the piston so that in the event of a failure they wouldn't break off.
If you have old glow plugs you can't use new ones. The threading has been moved.
If you have old glow plugs and your truck was produced after 4/2012 you should have the newer batch of valves so it's not a problem.
If you're still concerned about the glow plugs you can look at my post history where I had to replace one to find the ford writeup. You go in through the wheel well to take the plugs out.
rogue909 is offline
post #37 of 37 Old 10-28-2017, 09:30 AM
Quoted: 16 Post(s)
My truck is a 11/10 F350 (2011) so that would mean that I would have that problem. I do however have the ESP Warranty for the next 4yrs or 48,000. Along with the ceramic bearings in the turbo and the High Pressure fuel pump also known to detonate, it's hard feeling confident about this year. I plan on using the truck to tow a food trailer in the next few years. Seems like a lot of upgrades on top of an already pricey truck....grrr.
2011 F350 6.7L FX4
