Diesel Newbie - Page 2 - Ford Powerstroke Diesel Forum
6.7 Maintenance Info (2017-2019) 6.7 Maintenance Info
 4Likes
post #11 of 17 Old 01-10-2018, 11:19 AM
uncletony41's Avatar
manual states on the 2017 that we would get a message when water is detected in the filter, I do not see in maual stating to check this on a monthly basis.
2011-2016 had a diesel supplement guide, however 2017 does not.
uncletony41 is offline
post #12 of 17 Old 01-18-2018, 02:32 PM
cletusjermal's Avatar
Quoted: 395 Post(s)
One thing with optilube summer blend is it doesn’t have the demulsifier in it where the xdp does. It seems like one of the biggest issues with the 6.7 is water. So once I use up all my summer and winter blen I’m gonna get some of the xdp and just run that all the time. I had the summer blend left over from the 7.3 which didn’t seem to care about water.
Does anyone know if the fixed the water in fuel sensor with the 17? I know with the older 6.7 by the time the light on the dash came on it was too late and the fuel system was toast. My friend has an 11 and never got a water in fuel light and destroyed the whole fuel system. 10K to replace everything
2017 F350 6.7L 4x4 FX4 SRW CCSB Lariat Ultimate
Sold—2002 F350 7.3 4x4 SRW CCLB. GTP38R, PIS 175/80 injectors, Sam Wyse Stage 2 Trans, 6.0 cooler, Banks Intercooler, 4" Turbo back Exhaust, PHP tuned TS 6 position chip, CNC 4 Line feed, HPOP and HPX Lines. International bellowed up pipes. AFE Stage 2 Intake w/ Dry filter. Banks exhaust brake and smart lock. Hutch/Harpoon mod, 910 Valve springs, Billet intake plenums. Firestone airbags. Trailready full guard front bumper. PIAA Driving and Fog lights. Micky Thompson Wheels.
cletusjermal is offline
post #13 of 17 Old 01-18-2018, 04:59 PM
Quoted: 331 Post(s)
Manual states:
You should drain water from the
module assembly whenever the
warning light illuminates or a
message appears in the information
display advising you to drain the water
separator. This occurs when approximately
6.76 fl oz (200 ml) of water accumulates
in the module. If you allow the water level
to exceed this level, the water may pass
through to the engine and may cause fuel
injection equipment damage
You are right....it doesn't say to do it monthly but if you wait for the warning light to illuminate or the information display to pop a message, there's a chance that you are too late and risk an impact to your CP4 high pressure pump. So make sure you are doing it often enough to avoid the light coming on (or info center message). Maybe every other tank.
If you look towards the back of the manual (my online manual it's page 573) the scheduled maintenance chart does say that at every oil change. Fuel and water separator. Drain if necessary (or if indicated by the information display).
jd4010 is offline
post #14 of 17 Old 06-11-2018, 08:33 AM
MadeInDade's Avatar
Quoted: 13 Post(s)
Originally Posted by Painted Horse View Post
Reading the manual, I'm thinking " Where am I going to dump half a gallon of diesel" So like you I will take smaller samples unless I see a problem
Where do you dump the one liter you drain?
MadeInDade is offline
post #15 of 17 Old 06-12-2018, 12:23 PM
Quoted: 331 Post(s)
I dump mine into my diesel tractors. Or I'll use it for a fire pit starter. If you change your own oil, you can also mix it in with that and dispose of both at the same time (wherever you take your used oil in for recycling).
jd4010 is offline
post #16 of 17 Old 06-12-2018, 01:32 PM
"RLTW" Tennessee
F250_SUPER_4x4's Avatar
Quoted: 295 Post(s)
I have a tree that gets watered with diesel and oil weekly.
1974 F100 RC 351W/C4
1978 F250 Super Cab 400/C6
2015 F250 PSD CC KR 408/6R140
2017 Harley Ultra Limited 107/6SPD
F250_SUPER_4x4 is offline
post #17 of 17 Old 09-12-2018, 12:00 PM
Anti-Medic's Avatar
Quoted: 16 Post(s)
Garage
I too am a first time diesel owner. Outside of driving military vehicles and performing pmcs on them, I had no clue what owning a diesel truck entailed. 2018 6.7L F350 btw.
Retired Army 93-13
Paramedic
Anti-Medic is offline
Tags
6.7 diesel , maintenance
