COMPLETE MINI D2S 3.0 RETROFIT DIY GUIDE! - Page 28 - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
 18Likes
post #271 of 292 Old 05-05-2017, 06:25 PM
RayW72's Avatar
Quoted: 24 Post(s)
@Jkeller27
Looks good man. How's your projector cutoff alignment? It was tough enough with just the two. I couldn't imagine trying to align four of them.
Where did you tap for the switchback LED? Did you have any issues with the front turn signal circuits?
How bright is the switchback LED strip in the daylight?
RayW72 is offline
post #272 of 292 Old 05-08-2017, 08:29 AM
Quoted: 5 Post(s)
Originally Posted by RayW72 View Post
@Jkeller27
Ray-
"Looks good man. How's your projector cutoff alignment? It was tough enough with just the two. I couldn't imagine trying to align four of them. "
it is a pain to align all 4 of them. I still have some tweaking to do but I was under a time crunch and had to get them done that day for a road trip. I'm gonna have to take them back apart and secure them a little better because 2 twisted a little bit already
"Where did you tap for the switchback LED? Did you have any issues with the front turn signal circuits? "
i tapped into the stock market and turn signal I eliminated and added a resistor to prevent the hyper flashing.
"How bright is the switchback LED strip in the daylight?"
they are brighter than the stock marker lights. When I'm just moving the truck around the driveway at night I don't even turn on my headlights just the switchbacks
Jkeller27 is offline
post #273 of 292 Old 07-17-2017, 09:51 PM
Can someone post a link where all the photos on the first page can be viewed none of them are showing up? thanks!
Nemesis is offline
post #274 of 292 Old 12-23-2017, 04:58 PM
Did you ever get a photo link by any chance? Iím looking to start this project and trying to decide if I tackle myself or not. Local shop quoted $1400 for it...
jefhuf is offline
post #275 of 292 Old 01-09-2018, 05:00 AM
Quoted: 26 Post(s)
Wish we could see all the pictures in this thread I might attempt this. Stupid photobook!!!
oli6578 is offline
post #276 of 292 Old 01-09-2018, 05:17 AM
ZMANN's Avatar
Quoted: 3908 Post(s)
@oli6578
go find the appropriate Photobucket fix add on for your browser you should then be able to see the images
6.0 flush pdf
ZMANN is offline
post #277 of 292 Old 12-27-2018, 05:05 AM
Treatcg's Avatar
Quoted: 63 Post(s)
Are the 80mm rubber housing caps needed or can I just modify the stock ones?
Sent from my iPhone using Tapatalk
Treatcg is offline
post #278 of 292 Old 01-02-2019, 06:17 PM
dkeyt7's Avatar
Quoted: 7 Post(s)
I completed a Retrofit myself. I didnt do dual projectors but installed Profile peak hi lens leds in the top slot then added a switchback led strip. I love it so far.
ID:	712681   Click image for larger version
ID:	712683   Click image for larger version
ID:	712685   Click image for larger version
ID:	712687   Click image for larger version
dkeyt7 is offline
post #279 of 292 Old 01-03-2019, 06:33 AM
Treatcg's Avatar
Quoted: 63 Post(s)
Why did you install in the top slot? Do you still have adjustability up there. How about a wall shot of the pattern? Do you get hyperflash with LED Strips?
Treatcg is offline
post #280 of 292 Old 01-03-2019, 06:45 AM
dkeyt7's Avatar
Quoted: 7 Post(s)
I installed in the top just to have the dual projector look. I can take a picture but at low beam it is a typical step cutoff that you have with projector lights. When I turn on high beams it lights up the whole road. The top lights are either a "high beam" only light so I didn't have to worry about getting them adjusted like the projectors in the bottom housing.
dkeyt7 is offline
