2011 F-250 20in option, largest tires that can be run safely - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
 3Likes
  • 1 Post By HeavyAssault
  • 1 Post By toad0407
  • 1 Post By ehagerty
post #1 of 7 Old 12-06-2019, 09:19 AM Thread Starter
Quoted: 12 Post(s)
2011 Lariat Ultimate needs tires. Has the factory 20in upgraded rims with . I know I can safely go up to a 295/60-20 or a 295/65-20 but can you go to 35ís? If so is there an advantage, are they bigger and fatter. I see a lot of references to 35ís but the factory wheel width is 8in. I Like the look of the factory wheels so not planning on buying any in the near future
(cross posted on the other forum)
ehagerty is offline
post #2 of 7 Old 12-06-2019, 03:34 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 915 Post(s)
Feedback Score: 3 reviews
I wouldn't suggest running a 12.5" wide tire on a stock 8" wide wheel. For the record it seems as a 295/65-20 is actually larger all around over a 35x11.5 tire. Only a 35x12.5 tire would be larger in width.
The Evil Twin likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 7 Old 12-07-2019, 12:06 AM
toad0407's Avatar
Quoted: 16 Post(s)
Garage
Another thing to keep in mind if you are thinking of going with the 35s especially Toyo tires is the load rating although I agree with Heavy, I would not recommend going 35s on the stock rim due to the with difference. My 35x12.5 have the 121 load rating which are below the standard for my truck. I think the superdutys are required to have the 126 load rating if I am correct. My brother has 295/65/20 toyo AT2s on his truck and is rated up to 4080lbs whereas I am only rated for 3195 which is pretty low. Both have the E load rating. Also, most tire shops will not mount 35s on a stock rim due to safety reasons.
Sent from my iPhone using Tapatalk
HeavyAssault likes this.
toad0407 is offline
post #4 of 7 Old 12-07-2019, 06:08 AM Thread Starter
Quoted: 12 Post(s)
Thanks guys! I will look at the 295/65/20.
Is there a good reference to do a size comparison on different tires? to compare width and overall dia? Maybe tire rack?
ehagerty is offline
post #5 of 7 Old 12-07-2019, 06:14 AM
N.S.D.Q.
Quoted: 915 Post(s)
I go to the manufacturer pages. Nitto/Toyo have plenty of info that's up to date and correct.
post #6 of 7 Old 12-07-2019, 08:00 AM
The Evil Twin's Avatar
Quoted: 172 Post(s)
The 295/65 is the ticket on factory 20's with no lift. There is a thread on it around here somewhere. Most manufacturers measure out to 35.08- 35.19" tall and 11.65- 11.8 wide (section width, not tread) in that size. Ive done the research. Lol.
Depending on your options, the amount of clearance will vary but they'll fit.
2015 Oil Burner
CCLB Lariat Ultimate, 10k, Plow Package.
Mods have begun: 2wd Valance, Bully Dog GT, smoked lenses
The Evil Twin is offline
post #7 of 7 Old 12-08-2019, 01:37 AM Thread Starter
Quoted: 12 Post(s)
Thanks Evil Twin
ehagerty is offline
