295/60 R20 on 20x10 w/ 2.5" level kit still rubbing - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 12 Old 10-13-2019, 05:24 PM Thread Starter
I just had a 2.5" level kit installed and 295/60R20 Toyo AT II tires on 20x10 wheels. I was told this would not rub but they do. On turning they rub on the mud flaps. I do notice that the back end of the truck sits at least an 1" lower which would drive the back of the wheel well towards the tire. If I level the back will this fix the rubbing problem? The truck is a 2016 F350 Lariet.
ID:	724053   Click image for larger version
ElToro333 is offline
post #2 of 12 Old 10-13-2019, 06:16 PM
california deplorable
john galt's Avatar
Quoted: 3180 Post(s)
I am no expert especially on the newer trucks
but it looks to me like your front axle is sitting further back than it should
do you have any history on the truck?
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #3 of 12 Old 10-13-2019, 06:20 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 614 Post(s)
Feedback Score: 11 reviews
Track bar drop or aftermarket?
Alignment done?
Radius arm drop or aftermarket?
Wheel specs?
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #4 of 12 Old 10-14-2019, 03:09 AM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 239 Post(s)
99.9% of the time when you're told if something will fit, mudflaps aren't part of the equation. Try taking them off and see if they still rub. 99.9% of trucks with aftermarket wheels/tires don't run front flaps as they're the first thing to hit.
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 PMF lift on 325/60r20 Nitto M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #5 of 12 Old 10-14-2019, 03:53 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 940 Post(s)
Feedback Score: 3 reviews
Full wheel specs please. At first 20x10 seems to be the problem, I think the offset is what is killing the steering.
For the rear you would need to move the rear axle forward to get it centered in the wheel well. With your idea of going taller was my idea for my own ride. Lift the front 2.5" and go 1.5" taller on the rear, centering the rear axle. Not to mention the front axle can be centered/aligned better with adjustable arms.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #6 of 12 Old 10-14-2019, 04:31 AM
The Evil Twin's Avatar
Quoted: 176 Post(s)
Are they rubbing on the front or rear? It looks like there is too little offset (too much negative offset) on those wheels but that should only affect the front. There are a number of members that have put 295/65r20 on STOCK wheels with no rubbing. Those are larger tires by nearly an inch. Stockers are 8" wide with close to 0 offset.
2015 Oil Burner
CCLB Lariat Ultimate, 10k, Plow Package.
Mods have begun: 2wd Valance, Bully Dog GT, smoked lenses
The Evil Twin is offline
post #7 of 12 Old 12-15-2019, 11:01 PM
Stock 20" wheels have +40 offset.
cheetobuggy is offline
post #8 of 12 Old 12-15-2019, 11:03 PM
What is the offset on the 20x10's?
post #9 of 12 Old 12-16-2019, 05:17 AM
Quoted: 176 Post(s)
Really? Wow. I guess the info I found was way wrong. Dont recall where that was. Where did you find the OEM spec?
2015 Oil Burner
post #10 of 12 Old 01-09-2020, 08:31 PM
Drizzydrake2286's Avatar
Quoted: 7 Post(s)
Garage
What kind of leveling kit did you use? My 2011 is leveled and running 37s with minimal rubbing at full lock
Drizzydrake2286 is offline
