Power Tow Mirror Replacement - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 3 Old 09-18-2019, 02:20 PM Thread Starter
Hi All,
I am a brand new powerstoke owner! Just bought a new to me 2015 XLT. The previous owner hit something with the driver side tow mirror. The mirror operates as it should however it has a 2 inch by 2 inch hole in the plastic that allows rain/moisture/bugs ect into the mirror housing.
Does anyone know if it is possible to just purchase the plastics that house the mirror? Is the plastic only replaceable? Or do I need to bite the bullet and buy a whole new mirror? (Mirror not heated but is powered for extension and fold away)
Thanks for your help.
J
jb022 is offline
post #2 of 3 Old 09-18-2019, 03:41 PM
Quoted: 105 Post(s)
You can not buy the plastic pieces. You might can take a non-tow/manual mirror covers and replace it. Some people take the plastic off to replace the gears in it. Here is a link to do that. Might help if you decide to take it apart.
https://www.powerstroke.org/forum/6-4...d-fix-5-a.html
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 3 Old 09-24-2019, 12:53 PM Thread Starter
Ok. Thank you for your reply and the link. Much appreciated.
jb022 is offline
