2013 f250 driver mirror wiring diagram help! - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
 1Likes
  • 1 Post By Allspoolin4
post #1 of 10 Old 08-15-2019, 04:24 AM Thread Starter
Allspoolin4's Avatar
Quoted: 2 Post(s)
Hey guys I have a 2013 f250 that has a broken driver side mirror in a few different ways, so I bought a factory (used) one from eBay. It has all the power options where as my factory mirror did not, my factory mirror has heat, telescope, fold and mirrors. Where the eBay mirror has every option available, I believe, I tried re-pinning the wires to match mine but there is an extra yellow wire, and not all the features are working. So with all that being said I’m looking for a little guidance or if someone has a wiring diagram it would be much appreciated.
I attached 2 images one with less wires is my current mirror one with more is the eBay mirror.
ID:	721805   Click image for larger version
Allspoolin4 is offline
post #2 of 10 Old 08-15-2019, 07:03 AM
Quoted: 105 Post(s)
See if this will help any
Name:	Connector with memory.JPG
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 10 Old 08-15-2019, 04:12 PM Thread Starter
Quoted: 2 Post(s)
Thank you, so you are saying I should pin my connector to look like the thumbnail and try it? Or is that just the general diagram?
post #4 of 10 Old 08-15-2019, 04:26 PM
djmaguire's Avatar
Quoted: 1588 Post(s)
Garage
That connector pinout might be all that you need. But if you are looking for the wiring diagrams, you will find them in a post of mine in this thread here:
https://www.powerstroke.org/forum/6-...g-harness.html
There are three files. Mirrors should be in the last one of the three.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #5 of 10 Old 08-15-2019, 05:36 PM Thread Starter
Quoted: 2 Post(s)
Cool, thanks guys I’ll take a look and let you know what I come up with
post #6 of 10 Old 08-15-2019, 07:01 PM Thread Starter
Quoted: 2 Post(s)
May be a crazy question to ask but the thumbnail that you sent is for a 2014, would that matter because I’m not having a lot of the same wires at all my truck is a 2013
post #7 of 10 Old 08-15-2019, 07:05 PM
djmaguire's Avatar
Garage
Originally Posted by Allspoolin4 View Post
May be a crazy question to ask but the thumbnail that you sent is for a 2014, would that matter because Iím not having a lot of the same wires at all my truck is a 2013
I didn't post that thumbnail, but...
The wiring diagrams that I posted in the other thread and to which I referred were from the Ford Workshop Manual which covers 2011-1016. It's a reasonable bet, then, that anything within that span of years remained unchanged. ...at least according to Ford.
2004 F550 CC Lariat
post #8 of 10 Old 08-15-2019, 07:15 PM Thread Starter
Quoted: 2 Post(s)
Dj I tried viewing your post but my phones won’t display it I’m gonna try and have a look at in desktop version
post #9 of 10 Old 08-15-2019, 07:21 PM
djmaguire's Avatar
Garage
Dj I tried viewing your post but my phones wonít display it Iím gonna try and have a look at in desktop version
Good plan. I checked and they are working for download.
They are PDFs, so you will need both a method of download and a method of viewing.
2004 F550 CC Lariat
post #10 of 10 Old 08-15-2019, 08:35 PM Thread Starter
Quoted: 2 Post(s)
Man you know what I can’t figure out that damn diagram so I’m just going to take this ***** apart and swap harnesses lol thanks for you info guys I really appreciate it👍🏼
djmaguire likes this.
