Cab Lights and Sun Roof?? - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
 1Likes
  • 1 Post By Larry1013
post #1 of 4 Old 07-02-2019, 09:13 PM Thread Starter
bootcamp's Avatar
Quoted: 44 Post(s)
Garage
Did Ford put cab lights on these trucks with moon or sun roof. I'm in the market for a new truck. Did the search, just couldn't find the answer i was looking for.
Thanks
USMC MOTOR-T
05 F250 6" LIFT, Custom Fuel System, RR Kit, Fuel, Trans, Oil, Pyrometer Gauges, Fluid Damper, TSD & IDP Tunes, Hellmans Sump, 4.10 Gears, 625ARP, UCF O-Ring Heads FHG, Apex Ported Manifold, MBRP Exhaust, Atlas 40, Warren 175/75 Injectors, 68mm Pmax w/ Batmowheel, BPD Rad/Water Pump/Remote Stock Oil Cooler/7.3 Fan Clutch, Sinister Y Pipe, 6.4 Starter, Alradco Intercooler, Newest addition is a 2015 F250 6.7
bootcamp is offline
post #2 of 4 Old 07-02-2019, 11:33 PM
ars5147's Avatar
Quoted: 211 Post(s)
yes they did
1997 F350 CCLB 7.3
2019 F350 CCSB 6.7 Lariat Sport
ars5147 is offline
The Following 2 Users Say Thank You to ars5147 For This Useful Post:
bootcamp (07-03-2019)
post #3 of 4 Old 07-03-2019, 02:20 AM
Quoted: 105 Post(s)
Yes, my 2015 has the sun roof and cab lights. Cab lights are standard the DRW trucks and optional on the SRW trucks
HeavyAssault likes this.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #4 of 4 Old 07-22-2019, 12:33 AM
CocainePlatinum's Avatar
Quoted: 8 Post(s)
Yup same 15 with cabs and roof
CocainePlatinum is offline
