Fender Flares - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 8 Old 01-09-2019, 05:44 AM Thread Starter
Fender Flares
Im wanting to remove my OEM flares, but I don’t know what’s under them. Has anyone done this before? Anything I should know before doing this? TIA
Cris6.7 is offline
post #2 of 8 Old 01-09-2019, 05:48 AM
ars5147's Avatar
Quoted: 211 Post(s)
Should be double sided foam tape
1997 F350 CCLB 7.3
2019 F350 CCSB 6.7 Lariat Sport
ars5147 is offline
post #3 of 8 Old 01-09-2019, 09:57 AM
-Falcon-'s Avatar
Quoted: 397 Post(s)
Garage
you can use dental floss, work your way back and forth with it to cut through the tape, then use a mild solvent to wipe it clean. when I say mild, really mild. Solvent will take the clear coat/paint off if not careful. You can use other stuff too to get the residue off, but I forgot the name, goof off?
2007 F250 Crew Cab Lariat 4x4. Lots of upgrades, but not enough. It's tall, too tall. Yes, I'm obviously compensating for something.
UPGRADES:
EGR Delete, RedHead Steering Gear, Blue Spring Upgrade, ARP Studs, (Let's not mention this manufacturers name) Coolant Filter, (Let's not mention this manufacturers name) Blue Intercooler Pipe and Elbow Upgrade, Cold Air Intake, One-Up Offroad Traction Bars, XD Wheels and Nitto Ridge Grappler 37" Tires, LED Lights all around, 2013 Tailgate, 2008+ Power Mirrors, Pro-Comp XXX Dual Front Coilover Suspension, Custom Bedliner Sprayed Rocker Panels and Fender Flares, Amerihood Tpe E-Style Ram Air/Heat Extraction Hood, CompuStar Alarm with Remote Windows, Remote Start, and much more!
More upgrades to come, including Singer Alternator, and other engine upgrades.
NEW Custom Bumpers with Tire Carrier! Dual Winches!
-Falcon- is offline
post #4 of 8 Old 01-09-2019, 03:53 PM
Quoted: 115 Post(s)
All the above. Just tape holding them on. The paint is probably dirty as hell, so you'll need to really clean it and most likely there will be a line surrounding where they were because the paint would have faded over time as exposed to the sun vice the paint completely hidden.
The Resurrection
lowmpg is offline
post #5 of 8 Old 01-10-2019, 03:42 AM
ars5147's Avatar
Quoted: 211 Post(s)
And if they ever touched the paint, it could be worn into the clear, hopefully not the color though.
Use a hairdryer to heat them up, heat usually works wonders on any type of glue like that. '
And the best thing to remove any residue if it didn't just peel off after heating it, is one of those rubber eraser wheels. Then use a little solvent to wipe it down.
1997 F350 CCLB 7.3
ars5147 is offline
post #6 of 8 Old 01-16-2019, 07:02 PM
blackfords's Avatar
Quoted: 23 Post(s)
Why remove them....that truck looks awsome with them!
blackfords is offline
post #7 of 8 Old 01-16-2019, 08:10 PM
Quoted: 16 Post(s)
3M Adhesive Remover,
3M ADHESIVE CLEANER
available at most auto body paint suppliers will break the foam tape bond, and it will not harm the paint. I usually tape some paper towels over the area to be treated and then soak the paper towels. Let it work for 10 mins or so, (whatever the label says), and then the bond will break. Use the same stuff to do the final cleanup of the tape residue.
Derald.
Bulletproofed at 86,ooo miles. BPD HD air to oil cooler with cold weather, BPD egr cooler, BPD 6ph FICM, BPD water pump, Blue spring, KC stage 1 turbo, KDD heads, ARP studs, 6.4 banjo bolts, 6.4 starter, SCTx4 tuner, EDGE CTS2 monitor
2007 F250 CCSB 2wd
1989 Saleen Mustang Coupe
1984 Mustang GT350 Convert
1965 FFR Cobra Roadster
1957 Jaguar MK 1
Derald Rice is offline
post #8 of 8 Old 07-22-2019, 01:17 AM
CocainePlatinum's Avatar
Quoted: 8 Post(s)
Same wish I has some on mine
CocainePlatinum is offline
