Tire Info - Ford Powerstroke Diesel Forum
6.7 Exterior Discussion (2011-2016) 6.7 Exterior Discussion
post #1 of 7 Old 04-04-2018, 11:54 AM Thread Starter
Tire Info
I'm sure it's on here but I couldn't find it, but what is the largest tire you can put on without rubbing with stock height and 20" stock rims
KR1229 is offline
post #2 of 7 Old 03-20-2019, 06:03 AM
Quoted: 2 Post(s)
33's i believe.
Chuck07 is offline
post #3 of 7 Old 04-30-2019, 04:14 PM
Quoted: 5 Post(s)
Stock they come with 34.4 tires and i have seen a ton of people running 35 on stock suspension with no problems.
Chuckfx4350 is offline
post #4 of 7 Old 07-22-2019, 12:50 AM
CocainePlatinum's Avatar
Quoted: 8 Post(s)
Didnt realise the stocks were that tall. Looking to get some 22's with 35's
CocainePlatinum is offline
post #5 of 7 Old 08-08-2019, 12:38 PM
WildCard07's Avatar
Quoted: 10 Post(s)
Tire Info
I have read in many places that the 295/65R20 Toyo ATIIs would fit and was the largest you could go at stock height without rubbing. I have 20x9 Mickey Thompson wheels with 0 offset and 5 backspace and mine are rubbing on the wheel well liner and are a fraction of an inch from rubbing the sheet metal on the fender near the pinch weld while turning. I trimmed the wheel well liner to clear but I am concerned the tire will contact the metal during a tight turn with the wheel stuffed. I also have a heavy steel front bumper replacement weighing the front end down a bit. I was hoping not to have to lift but I guess I will have to now.
WildCard07 is offline
post #6 of 7 Old 08-08-2019, 05:32 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 609 Post(s)
Feedback Score: 11 reviews
A 35x11.5 (and the metric equivalent) are the biggest you can go on stock without any rubbing.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #7 of 7 Old 08-08-2019, 05:33 PM
Quoted: 115 Post(s)
Those will be pushed out pretty far, may rub on the front bumper at lock.
The Resurrection
lowmpg is offline
