Driverís door rattle B&O system - Page 2 - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2017-2019) 6.7 Electronics Discussion
post #11 of 12 Old 09-12-2019, 09:34 AM
Quoted: 4 Post(s)
Originally Posted by teameyecatcher View Post
Thanks man. If you figure your rattle out first or I do the same for either one I have, letís update the thread.
I found the rattle. It's the 2 middle nut plates attached to the silver metal door panel mount. Tighten the two bolts to prevent them from rattling.
ID:	723059   Click image for larger version
ID:	723061   Click image for larger version
Deluxe247 is offline
post #12 of 12 Old 09-12-2019, 11:32 AM Thread Starter
Quoted: 7 Post(s)
Awesome info. So you shouldn't even have to pull the door panel to do that, then? Just tighten the two bolts by the handle?
I just got mine back from the dealer today. I knew it had to be a blown speaker, so I made them check it, and so it was.
teameyecatcher is offline
