2013 SuperDuty Audio/Stereo upgrade - Page 4 - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 2Likes
post #31 of 40 Old 09-12-2014, 11:20 AM Thread Starter
dieseldesi's Avatar
Quoted: 5 Post(s)
Originally Posted by Capt dong View Post
nice install. how were the tweeters fitted?
i just installed a set of hertz 5x7s all the way around since they were given to me. definite improvement over stock. i got a couple tweeters that i want to stick into the factory mount but looks like the factory ones are glued into a plastic bracket. my truck is an 08 but looks like a lot of the stuff is very similar.
I don't have a pic of it but it fits int he factory hole in the panel they normally have a metal strip with holes that they use to secure it.
dieseldesi is offline
post #32 of 40 Old 09-12-2014, 09:17 PM
barobbin's Avatar
Quoted: 4 Post(s)
where could i get those adapters you used to fit your 6.5"s in the 5x7 hole??
barobbin is offline
post #33 of 40 Old 09-13-2014, 01:13 PM
cjf250sd11's Avatar
Quoted: 2 Post(s)
Couple pics for ideas. First one is the install on my 2014. Ford makes it easy on the '13+ since the amp for all speakers go through the amp attached to the OEM sub. Makes it very easy to intercept the wires for the summing unit. The '11-12 I used the void behind the radio inside the dash to place the summing unit.
cjf250sd11 is offline
post #34 of 40 Old 09-13-2014, 06:42 PM Thread Starter
dieseldesi's Avatar
Quoted: 5 Post(s)
Installer made those.
post #35 of 40 Old 09-13-2014, 06:45 PM Thread Starter
dieseldesi's Avatar
Quoted: 5 Post(s)
Nice install.....where did you put the Sony factory amp?
post #36 of 40 Old 09-14-2014, 07:36 AM
cjf250sd11's Avatar
Quoted: 2 Post(s)
It is mounted on the back of the amp board for the '14 while the '11 was left in place under the dash.
post #37 of 40 Old 04-16-2015, 07:41 AM Thread Starter
dieseldesi's Avatar
Quoted: 5 Post(s)
After one year the system is still doing great and absolutely no issues.
post #38 of 40 Old 04-16-2015, 09:21 AM
Quoted: 3 Post(s)
Great clean install! Now if you can just do mine
Andy2015F250 is offline
post #39 of 40 Old 04-20-2015, 10:55 AM Thread Starter
dieseldesi's Avatar
Quoted: 5 Post(s)
If you can drive to Dallas we can get it done
post #40 of 40 Old 04-20-2015, 01:21 PM
Quoted: 3 Post(s)
Going to have to consider that!
