Ford Remote Access - Page 27 - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 14Likes
post #261 of 273 Old 01-09-2017, 07:06 PM
Quoted: 9 Post(s)
yes you did.. i had posted this before you emailed me.. thank you!!
Brevuelta is offline
post #262 of 273 Old 01-11-2017, 08:47 AM
Quoted: 9 Post(s)
A dealer here in Miami wants 1.5 hrs ate 105 an hour to register my sim and generate a pin!!!! hahahaha i installed all the components myself... WHAT A JOKE.. can someone help me register my sim and get me a pin?? thanks in advance Barney
post #263 of 273 Old 01-11-2017, 09:05 AM
Quoted: 105 Post(s)
Wish I could but do not know anyone offhand. Check the F150 forums online. They might know someone.
I can save someone this Sim activation fee if they want to add cell access using a pre-activated module. I am removing from my car and truck, so there will be 2 modules available. I have decided I do not have enough cell coverage in my area to use it to justify the yearly fee. One will show Lincoln and one will show Ford when activated by the buyer. $125 each shipping included in the USA.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #264 of 273 Old 12-01-2017, 08:37 PM
Quoted: 9 Post(s)
Does anyone know if the 2015 modular remote access components will work with the 2017 Super Duty?
life_alert is offline
post #265 of 273 Old 12-02-2017, 01:47 AM
Quoted: 105 Post(s)
The VSS (security module) is not the same as the 2011-2016 trucks. The VSS is pn FT4Z-19A361-A. The cellular module for remote access is the same. The RMA pn DL3Z-19A390-B.
https://www.levittownfordparts.com/s...8_413_419.html
life_alert likes this.
Larry
post #266 of 273 Old 12-02-2017, 08:45 AM
Hello,
glad you found the right guys to activate your system. Its a great system and works well. Have had system in for 2 yrs. I have just purchased the 2nd one for the wifes new 2017 Taurus will be installing this afternoon.
Now here is the issue hopefully the company that makes the software will upgrade both for Android and Iphone or we will all lose this great app and tool.
Cheers
mccrowe is offline
post #267 of 273 Old 02-24-2018, 04:34 PM
Quoted: 7 Post(s)
I just picked up a 2018 Platinum F250.
my question is...
do I already haveDL3Z-19A361-A?
I see some things in the settings about perimeter alarm.
If so.. then I just need that box for 310 that i see dealers advertising.. correct?
My dealer wouldn't be considered on the cutting edge of tech.
Thanks
JP
MeinGreaseCar is offline
post #268 of 273 Old 09-03-2019, 08:27 AM
Larry,
Quick question Larry, I have read this whole thread and did not see the answer. So I wanted to see if I missed something. I have a 2012 Lariat. I have a factory remote start. I have already added the VSS and the long range antenna. I am not looking to add the RMU. The unit came with a long wire harness. My two questions are: do I need the harness is the first question. Second, does the RMU go on the driver side where I have the VSS or the passenger side where the TPS module is as shown in the pdf?
Thanks for all your contributions to the forum!!!
RocketKatckR!
RocketKatchR is offline
post #269 of 273 Old 09-03-2019, 01:55 PM
Quoted: 105 Post(s)
The long range antenna has a long flat/ribbon cable to go between the VSS and the windshield mounted long range antenna.
Sounds like you have the OBDII version of the VSS.
The RMU is a separate box would also plug into the VSS should you desire to add it one day for cellular remote start abilities. The cable for the RMU is permanently attached to the RMU box and is relatively short.
This long range remote start and/or the RMU is totally separate from the RF remote start that used the IKT (integrated key fob).
I think I answered your question, but, if not, ask again and maybe a photo or two of the cable/VSS or...
Larry
post #270 of 273 Old 09-03-2019, 02:23 PM
Larry,
Yes, it is an ODBII version, sorry for not thinking to make that distinction. Having said that I am sure it RMU plugs into the VSS and I agree it has a short cable. That part that was confusing me was one. The pdf's seem to show the RMU being installed near or above the TPMS above the glove box. The other confusing part would be that long cable that I will take a picture and send a part number to you tonight when I get home.
Pretty sure I am good though. I would just like to be sure, might clear up some things for other people on the forum as well. :-)
Thanks,
RocketKatchR.
