nav screen use in motion - Page 3 - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #21 of 52 Old 12-17-2010, 06:45 PM
TW720HVY's Avatar
Quoted: 2 Post(s)
Originally Posted by Wakepowell View Post
The area behind the radio is very tight but there is a hole in the metal dash structure directly above the radio that I fit the LockPick module into. I took pictures of the installation. Once I get a chance to download them I will post the pictures.
Thank you... I would really appreciate that.
Previously Owned
2011 F-350 Lariat Crew Cab, White with Black interior, SRW, Short Bed, FX4
TW720HVY is offline
post #22 of 52 Old 12-18-2010, 07:47 AM
Here are a few photo's from my installation of the LockPick
ID:	20673   Click image for larger version
ID:	20674   Click image for larger version
ID:	20675   Click image for larger version
ID:	20676   Click image for larger version
Wakepowell is offline
post #23 of 52 Old 12-18-2010, 08:30 AM
TW720HVY's Avatar
Quoted: 2 Post(s)
Great pictures... thank you.
I am not sure where the "Lock Pick" box went. Also where did the wire bundle goes after it was all connected?
Thanks for your help... this is HUGE!
Previously Owned
TW720HVY is offline
post #24 of 52 Old 12-18-2010, 09:33 AM
I put the LockPick directly above the radio. There is a hole in the metal dash structure right above the radio that the device fit into. There is little to no room behind the radio.
post #25 of 52 Old 12-18-2010, 12:35 PM
BALL D's Avatar
ok thanks i had 2009 just got the 11
BALL D is offline
post #26 of 52 Old 12-19-2010, 11:13 AM
TW720HVY's Avatar
Quoted: 2 Post(s)
GREAT thanks again for the help!
Previously Owned
TW720HVY is offline
post #27 of 52 Old 12-26-2010, 03:19 PM
I don't know if this applies to this unit but on other factory Nav units if you grounded the wire that is the parking break sensor (thereby fooling the Nav unit that the parking break is down) this typically unlocks everything.
Don't know if this applies with Ford sync enabled units...
pisymbol is offline
post #28 of 52 Old 12-30-2010, 09:34 AM
Quoted: 7 Post(s)
So, in short, either one does the exact same thing, but the PAC is just a little more expensive?
teameyecatcher is offline
post #29 of 52 Old 01-22-2011, 06:24 PM
4x4ord's Avatar
Quoted: 7 Post(s)
I have heard bad press about Lockpick's customer service and so would prefer to buy a PAC NU-FRD 1. I want to use it to view multiple cameras. I know the Lockpick allows for this - does anyone know for certain if the NU-FRD allows multiple cameras. Also do I need to purchase additional harness for a second backup camera? (My truck has the factory camera in the tailgate and I desire to add one on the back of my RV)
4x4ord is offline
post #30 of 52 Old 01-23-2011, 04:29 AM
brmccolley's Avatar
Doesn't apply here
Ford has put a speed sensor into this system. I've been driving in town with the "destination" Nav screen displayed and watched option switch from shadow to available options when the speed drops below about 10 miles per hour.
brmccolley is offline
