proximity alarm - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 1Likes
  • 1 Post By The Evil Twin
post #1 of 5 Old 01-08-2020, 06:09 PM Thread Starter
Quoted: 3 Post(s)
proximity alarm
Is there any easy way to semi-permanently cut this damn thing off? Apparently it thinks the load distributing hitch that will pretty much stay installed in is something I'm going to back into.
packratt is offline
post #2 of 5 Old 01-09-2020, 02:40 AM
Quoted: 105 Post(s)
Not aware of anyway to cut it off. Not aware of anyone who has compared the XT truck as built data with the Lariat or others with the backup sensors to see what is different.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 5 Old 01-09-2020, 10:48 AM
My backup sensor in my 2011 went bad and wouldn't beep any more. I would get a backup sensor fault at start up. I tried turning it off in the settings, but it would just come back on each time I started it up. If disabling the sensor in the settings doesn't work I would imagine unplugging the sensors at the bumper would, but you'll get that sensor error message each time. After a while I got used to it and acknowledging it became part of my normal start up routine.
Noel04z06 is offline
post #4 of 5 Old 01-10-2020, 04:08 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 950 Post(s)
Feedback Score: 3 reviews
Unless you get smart with ForScan I can't give you a way to shut it off "semi-permently".
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #5 of 5 Old 01-10-2020, 06:04 AM
The Evil Twin's Avatar
Quoted: 176 Post(s)
Or maybe get smart with some wiring. I never got around to it yet, but was thinking of fabricating a 7 way plug with some resistors to "fake out" the truck into thinking I have the trailer connected. Then I could just put that plug into the 7 way on the truck when I wanted. My thought was to plug the trailer in and disconnect one wire at a time to see what told the truck it was there. My bet is it has to do with the brake or battery system.
Hydro likes this.
2015 Oil Burner
CCLB Lariat Ultimate, 10k, Plow Package.
Mods have begun: 2wd Valance, Bully Dog GT, smoked lenses
The Evil Twin is offline
