2nd hand truck, 2 keys, only one performs remote start - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 3 Old 12-02-2019, 11:12 AM Thread Starter
Quoted: 16 Post(s)
So my 2nd hand 2011 6.7 Lariat came with 2 keys, one well worn and one looks like new. Both keys function fine, truck start, unlock, etc etc..... just like each other but. The newer looking will not remote start the truck. Is there something i need to program? The only key will remote start. I read the manual and did not see anything addressing programing remote start jut to turn it on and off in the dash. It is turned on
ehagerty is offline
post #2 of 3 Old 12-02-2019, 02:48 PM
Quoted: 105 Post(s)
It is hard to say if there is a simple method. For you to get the second (newer) key to remote start the truck, you might need a third key programmed. You need two programmed keys to program a 3rd key. Once you get it programmed, you might be able to "reprogram" the new fob key.
If you have the key pad on the door, try taking both keys and turn the first key on and then off, remove the key, turn the second key on within like 10 seconds. It should bring up the remote entry code after the screen clears of the intro and etc. If not, then the keys might not be unique in the PATS.
I would not guarantee this method to work or not, since you do not know how the new fob key was initially programmed. If you can't program a 3rd key, you will need to have the PATS reprogrammed for both fob keys. You can get the dealer (costly) or locksmith (moderate cost) to reprogram PATS. Another option is use FORScan on a laptop/computer with free license to reprogram PATS for the two fob keys. Once you have 2 "good and unique" keys, you can program additional keys or fobs.
You can have a total of 8 keys of which only 4 can be fob keys (IKT keys).
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 3 Old 12-04-2019, 01:05 AM Thread Starter
Quoted: 16 Post(s)
Thanks Larry,
I tried this and no code comes up. Someone I know suggested the key might be set up as a valet key? Have you heard of this? Our trucks do not really have another valet mode?
ehagerty is offline
