Wiring Harness - Clearance Running Lights - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 4 Old 10-26-2019, 05:55 AM Thread Starter
dimitrios713's Avatar
Quoted: 6 Post(s)
Good morning,
Is there a simple way I can figure out if my 2016 F250 Lariat has the necessary factory wiring harness to install cab clearance running lights. I'm trying to avoid removing parts/pieces prior to ordering materials.
Thanks so much
Dimitrious
dimitrios713 is offline
post #2 of 4 Old 10-26-2019, 04:27 PM
Quoted: 115 Post(s)
Originally Posted by dimitrios713 View Post
Good morning,
Thanks so much
Dimitrious
If it doesn't have lights on the roof, it doesn't have wiring for it.
The Resurrection
lowmpg is offline
post #3 of 4 Old 10-27-2019, 02:57 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 928 Post(s)
Feedback Score: 3 reviews
Most of the upper trims (Lariat or higher) share the same base harness. You would most likely have the main harness that will allow the connection of the harness that feeds the clearance lights. You will not have the harness that feeds up to the roof and light base.
I want to say the harness connection is going to be on the passenger side down the pillar or at the floor.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #4 of 4 Old 10-27-2019, 05:47 AM
RayW72's Avatar
Quoted: 35 Post(s)
Here are two threads on the subject of adding them. It is not that hard to do. You will have to buy the harness but it is plug and play.
https://www.powerstroke.org/forum/6-...er-lights.html
https://www.powerstroke.org/forum/6-...ts-2011-a.html
2015 Tuxedo Black Platinum 6.2L
RayW72 is offline
