Do I have remote start? - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 4 Old 08-21-2019, 08:27 PM Thread Starter
Quoted: 7 Post(s)
Well the answer is apparently yes I do as per what the previous owner tells me.
I have only one 4 button key and beat to **** so im not sure if it even functions properly but I can't seem to get my truck started via remote.
Lock doors twice then press the lower right button two times and it's supposed to start right?
Im told it's stock.
Is there a way I can test to see if the setup functions properly so I can trouble shoot the key issue? Is there a module I can look for that will confirm its installed?
Thanks in advance. Im new here and have tons of questions
Sent from my Pixel 3 XL using Tapatalk
FiEnD is offline
post #2 of 4 Old 08-21-2019, 09:08 PM
Quoted: 115 Post(s)
With the key pointed up: top left button (lock) once and bottom right button twice.
If the truck honks twice then there is a malfunction somewhere.
Forscan will let you see if itís enabled or not.
Sent from my iPhone using Tapatalk Pro
Jav_eee is online now
The Following User Says Thank You to Jav_eee For This Useful Post:
FiEnD (08-21-2019)
post #3 of 4 Old 08-21-2019, 09:29 PM Thread Starter
Quoted: 7 Post(s)
Thanks! Will try when I get the truck back from having ujoints and wheel bearings done.
Is there a spot on this forum that goes over Forscan? I want to learn to use it but im a little nervous
FiEnD is offline
post #4 of 4 Old 08-22-2019, 02:45 AM
Quoted: 105 Post(s)
You should be able to scroll through your center display option to see if you have remote start. You can get more info in your owners manual.
You can download an owners manual from Ford.
https://www.fleet.ford.com/partsands...owner-manuals/
or
https://owner.ford.com/tools/account/sign-in.html
ID:	722095   Click image for larger version
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
The Following User Says Thank You to Larry1013 For This Useful Post:
FiEnD (08-22-2019)
