2014 F250 Fog light issue! - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 3Likes
  • 1 Post By Larry1013
post #1 of 6 Old 06-19-2019, 04:12 PM Thread Starter
StrokinJoe14's Avatar
Hello everyone! I have a 2014 F250 and I'm having issues with the fog lights. I have checked fuse 47 in the kick panel and it is good. I have checked the wiring in the front bumper and I can power the lights with an external battery at the factory plug. I've also purchased a new motorcraft headlight switch and I still have nothing. The indicator on the headlight switch doesn't even come on anymore. I'm not sure what else to check at this point. Any help is greatly appreciated!
StrokinJoe14 is offline
post #2 of 6 Old 06-19-2019, 06:36 PM
Quoted: 105 Post(s)
IF fuse 47 is good, then it appears you might have a bad BCM.
ID:	720093   Click image for larger version
Heavy_GD likes this.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 6 Old 06-19-2019, 07:27 PM Thread Starter
Well, dang. I may end up putting them on an upfitter switch. Will I be able to see what's going on if I get the forscan app?
post #4 of 6 Old 06-19-2019, 07:42 PM
Quoted: 105 Post(s)
Probably not with FORScan.
If you check the drawings I posted, you will see the output from fuse 47 and the fog lamp relay feed back to the light switch to illuminate the orange fog light indicator. To me, if the fog lamp indicator does illuminate, then the fag lamp relay is not energizing. The BCM is not serviceable. The BCM stores your PATS key codes.
Might be best and cheapest solution is to put them on an upfitter switch as you are indicating.
Larry
post #5 of 6 Old 06-20-2019, 10:41 AM Thread Starter
Thank you for the help! I'll wire them to an upfitter this weekend. Someone had already replaced the 15 amp fuse with a 30 amp fuse before I got the truck. I'm pretty sure the headlight switch didn't like the 4 fog lamps in the bumper anyways.
post #6 of 6 Old 06-20-2019, 03:46 PM
Quoted: 105 Post(s)
Doubt it was the headlight switch that didn't like the 4 fog lamps in the bumper but the BCM. An FET controls the fog lamps. FET's can be blown by overloading the circuit they control. I highly suspect the previous owner blew the FET.
In an FET circuit, one should only use the circuit to control a relay that supplies the power to the high amp load. This will avoid blowing the FET and requiring the BCM to be replaced.
Larry
