2016 f250 6.7 4x4 PCM failure - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 2Likes
  • 1 Post By HeavyAssault
  • 1 Post By roverjosh
post #1 of 9 Old 04-12-2019, 09:26 AM Thread Starter
Quoted: 2 Post(s)
Posting this Incase anyone runs into this issue or has ran into this issue. I have a 2016 f250 with 26k miles. The other day I got it in, started the truck and all dash lamps came on and gauges would not work. I drove a few blocks, pulled over and shut off the truck and attempted to restart the truck and it would not start. After a few start attempts and waiting about 20 minutes, I finnaly got the engine to start. I was able to drive to the dealer. The dealer diagnosed a faulty PCM and is stating it will not cover it because I have an after market system(Idatalink maestro module interface) plugged into the OBD2 port. The idatalink system monitors the high speed can for gauge information, tire pressures etc. and displays data on my alpine X208u head unit. it is equivalent to plugging in a scan tool to monitor readings (which I can also do with my alpine x208u). With the idatalink plugged in, the high speed can test’s ok- around 5-6 volts added value when key is on. No voltage, current, or short in the connector coming from the idatalink module. I had a meeting with the dealer and asked them to show me how the idatalink system damaged the PCM- they cannot show any hard evidence, but I can show and explain that it did not take out the PCM with my test’s that i presented to them. Before I had this meeting, they wanted me to buy a pcm parts and labor 2k. me being me, got down to the bottom of things and realized they just don’t want to cover it because there is an after market component on the truck. I referred to this https://www.autocare.org/government-...-warranty-act/ and explained this to the manager- only after going through all of this they are calling a field service rep out. The truck has been in the shop for a week now. Any advice or input on what I should do next would be greatly appreciated.
PasadenaMike626 is offline
post #2 of 9 Old 04-12-2019, 11:54 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 667 Post(s)
Feedback Score: 3 reviews
Stick to your guns. They have to PROVE your device caused the issue. I had a PCM getting a stray voltage reading causing issues while in the Jenny Craig program. I was honest with the Service Manager and Tech. They were able to get it covered as the testing required by Ford found one of the voltage inputs out of spec.
Larry1013 likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
The Following 2 Users Say Thank You to HeavyAssault For This Useful Post:
PasadenaMike626 (04-13-2019)
post #3 of 9 Old 04-12-2019, 12:06 PM
Quoted: 3 Post(s)
Look up the Magnuson-Moss warranty act. This act says that the dealer has to show that the installed part caused the failure. Your warranty can't be voided or you denied coverage simply because of the use of the aftermarket part.
Romans10-9 is offline
The Following User Says Thank You to Romans10-9 For This Useful Post:
post #4 of 9 Old 04-13-2019, 02:31 AM
N.S.D.Q.
Quoted: 667 Post(s)
If you notice the OP placed a hyperlink in his post to the MM act.
post #5 of 9 Old 04-13-2019, 03:16 AM
Quoted: 3 Post(s)
Shoot!!! I guess I need to order that hooked on phonics kit I keep hearing about.
post #6 of 9 Old 04-13-2019, 07:02 AM Thread Starter
Quoted: 2 Post(s)
I have been completely honest with the technician, service advisor, and service manager. As a heavy Railroad equipment mechanic myself, I know that if the operator is being totally honest, problems are solved MUCH easier. They just seem very hesitant to move forward with a diagnosis because of my equipment. I have been in the technicians shoes before and I know that diagnosis can eat into their flat-rate pay scale thus resulting into the issue not being priority for them. I am prepared to ask questions about what diagnostic patterns were taken to get to where we are at today. I have studied the wire schematics and know how to eliminate problems. The circuit is a fairly simple circuit. I would hate to be "that guy" that shows up with my Fluke meter and a set of wire schematics to perform a diagnosis but, if that what it comes to make my point I will. I will keep you guys posted as time progresses. At this point I am think I should have taken the truck to a different dealer. Thank you guys for your input so far.
post #7 of 9 Old 04-15-2019, 06:42 AM
roverjosh's Avatar
Quoted: 36 Post(s)
Garage
Its a bummer you have to deal with this. Its a bummer that warranty work doesn't pay right so Dealers put it as a low priority or in this case use it as an excuse to try to blame a customers' part. Thats just plain fraud.... IF and WHEN you get it proven that its something on the truck, they should be writing you an apology.
Curious to see how this unfolds.
When it comes to mechanics, everything I know is from either breaking it or watching someone else do the same. Then I had to fix it....Is that bad?
Murphy's Law: "things will go wrong in any given situation, if you give them a chance."
roverjosh is offline
post #8 of 9 Old 04-18-2019, 07:51 PM Thread Starter
Quoted: 2 Post(s)
****UPDATE****
2 days ago (Tuesday) I received a call from the service advisor stating my truck would be ready today (Thursday). I went to the dealer yesterday(Wednesday) as I got a phone call from the SA stating that the PCM was installed and the tech had a few questions for me. I went back and spoke with the technician. He asked me about a wire that I had spliced into for the reverse camera power (+) I installed and purchased from camera-source.com (Connector 2280D Pin 13- feeds trailer reverse relay and reverse lights) and he wanted to cut it- I had no problem with that so he did. When I did the install I followed the directions that the manufacture suggested- they specifically wanted to tap into that circuit (not a cheap amazon product). I explained and broke down the circuit for him. He told me they decided that they would install the PCM under warranty. The PCM was installed and the truck was driven 10 miles. While I'm waiting for the truck to be pulled up to the drive today, the SA comes up to me and explains to me that the truck wont start and all lights are displayed on the dash again (original symptoms). Everything that I have installed on the truck (Idatalink maestro and reverse camera) has been disconnected at this time and the truck is still having problems. To add the icing to the cake, the technician that was working on my truck was let go yesterday. So now I am back in the rental trying to get sleep at night . I have been in touch with ford customer service that they told me that the "dealer is their eyes and ears" and that I have to work with the service manager on getting this issue resolved (over seas personnel). I was really expecting to hear other results but I guess the customer service isn't what its hyped up to be.
I will keep posted updates as I get them. Hoping this issue doesn't reflect on my future purchase's of Ford vehicles.
post #9 of 9 Old 04-19-2019, 11:09 AM
roverjosh's Avatar
Quoted: 36 Post(s)
Garage
Techs stink
****UPDATE****
I did not purchase an "extended" warranty when I bought my 165k truck. I am thinking it won't do me any good to know, considering your experience with dealers. I'm better off just keeping maintained and just pray.
Cheers and best of luck.
PasadenaMike626 likes this.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Lift kit recommendation for a 2016 F250 g.c. bandit 6.7 Performance Parts Discussion (2011-2016) 8 08-21-2018 08:51 AM
Best leveling kit for my 2016 F250 4407lifted Suspension & Steering 18 11-17-2016 05:05 PM
2016 F250 build SFWD1934 6.7 Performance Parts Discussion (2011-2016) 14 08-10-2016 03:40 AM
