LED bed lights wiring question - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 9Likes
post #1 of 13 Old 03-20-2019, 05:44 AM Thread Starter
fordmanmark1's Avatar
15’ 350 Platinum. I have a set of LED bed lights I mounted in my bed. I originally had them hooked up to one of my AUX switches and that’s become a PITA cuz I have to have the key on to power up the bed lights. Unless someone knows a mod to have power to those at all times?(another question lol) anyway...I bought a waterproof switch for the bed and I came across I a thread but I can’t find it now of how someone tapped into and witch wire in the back for constant power so I can just simply hit the switch. Any help with that I would appreciate it Thanks.
2015 F-350 Platnum FX4 Superduty 4X4 6.7L crew cab Longbed 3.55's 5th wheel prep
Old truck's 95' 7.3 LB EXT 4X4 285,000 miles very much Missed! 08' F-250 6.4 fully deleted
Lots of mods to come
Quote:The right of the people to bear arms shall not be infringed.
fordmanmark1 is offline
post #2 of 13 Old 03-20-2019, 01:15 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 665 Post(s)
Feedback Score: 3 reviews
I'd run a power lead with fuse off the battery myself.
fordmanmark1 likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 13 Old 03-20-2019, 01:19 PM Thread Starter
I thought doing that myself. Thanks. It works for you?
post #4 of 13 Old 03-20-2019, 01:32 PM
voodooridr's Avatar
Quoted: 809 Post(s)
I have a fused wire running off the L/S battery powering my LED bed lights (ebay specials) and camper dome light
Waterproof pushbutton switch drilled into the L/S rear stake pocket with all the splices and connections behind the L/S tail lamp
Sent from my SM-G960U using Tapatalk
fordmanmark1 and HeavyAssault like this.
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
post #5 of 13 Old 03-20-2019, 02:01 PM Thread Starter
Ok, Iím drawing a blank. What is the L/S? I should know the abbreviations
Sent from my iPhone using Tapatalk
post #6 of 13 Old 03-20-2019, 02:03 PM
voodooridr's Avatar
Quoted: 809 Post(s)
Left Side
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
post #7 of 13 Old 03-20-2019, 02:07 PM Thread Starter
Left Side
Lmao that crossed my mind but thought hummmm? Haha thanks
post #8 of 13 Old 03-20-2019, 02:10 PM Thread Starter
Iím fining to attach to the wire thatís coming from the lights, in my cab to the aux switch and go to the battery direct with a fuse. I already put a switch in. Iíll take some pics when Iím done tonight. Thanks for the help/suggestions.
HeavyAssault likes this.
post #9 of 13 Old 04-03-2019, 03:45 PM
2014six.7's Avatar
Quoted: 5 Post(s)
I have mine tapped into my rear parking lights, when I hit the key fob or turn the parking lights on they light up. The only thing that’s kind of annoying is they shut off after about 15 seconds unless you manually turn the parking light on.
Thanks and have a goodun, Rollo!
2014six.7 is offline
post #10 of 13 Old 04-03-2019, 05:57 PM
I have mine hooked up to the running board light plugs on each side of the truck. It works off the same circuit as my high mount cargo light. I also added led strip light above my running boards on the same plug. Works great.
GeoffH is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
wiring and pcm question. vonzool 94-98 7.3L General Powerstroke Discussion 0 01-21-2018 09:11 AM
2012 6.7 No rear lights when head lights are on thehoovers4 6.7 Problems Forum (2011-2016) 6 12-19-2017 08:02 AM
Installing fog lights on my 11 that doesn't have them?? GSully23 6.7 Exterior Discussion (2011-2016) 2 11-17-2017 09:52 PM
Turning off the lights and unlocking the doors... GracieAllen General Diesel Discussion 4 11-12-2017 06:14 PM
Adding auxiliary lights? GracieAllen General 6.7 Discussion (2011-2016) 22 10-17-2016 08:14 PM
