Battery light with high idle and odd shifting - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 11 Old 11-26-2017, 02:42 AM Thread Starter
Hi, new to the forum but long time creeper. I have a 2014 6.7 and the battery light has come on and is staying on. Ive tested both alternators and batteries to be good (14.5 volts and 12.5 volts respectively). To accompany the battery light I have only noticed a higher idle (750rpm vs normal 500ish) and hard shifting especially down shifts.
Not sure whats going on here. Can't seam to find any obvious wire breaks or miss connections.
Help?
Thank you in advance!
Edit:
Not sure if its related or not or if its working correctly but my auto temp doesn't seam to do much at all untill the engine thermostat opens (at least that what I think os happening). Set in auto high heat there is very little air coming out of the windshield vents. It styas that way untill my temp gauge moves a bit then the fan kicks on high and heat comes. Maybe I have an issue with my supplemental heater? Thanks!
Neurotoxin is offline
post #2 of 11 Old 11-27-2017, 12:07 AM
Drunk Post Extraordinair
Old King Coal's Avatar
Quoted: 214 Post(s)
Garage
I don't have much, but did you multimeter the batteries? How old are they? It might be worth pulling them and carrying to a part store and having them load tested. I've heard they can hold voltage, but when they get called on they aren't up to snuff.
It's where I'd start.
So strong is Tradition that later generations will dream of what they have never seen.
Old King Coal is offline
post #3 of 11 Old 11-27-2017, 07:36 AM Thread Starter
Looks like this fuse block maybe my culprit. Had a look after seeing this thread: https://www.powerstroke.org/forum/gen...=2&gid=1&pid=1
post #4 of 11 Old 11-27-2017, 07:38 AM Thread Starter
Ive tested both batteries and alternators to be good. Batteries are both only 2 years old and take load well.
post #5 of 11 Old 11-27-2017, 07:39 AM Thread Starter
Quite corroded and dirty
post #6 of 11 Old 11-27-2017, 12:07 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 821 Post(s)
Feedback Score: 3 reviews
14.5 volts and 12.5 volts should be your readings, not amps.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #7 of 11 Old 11-27-2017, 01:23 PM Thread Starter
Yes, thanks
post #8 of 11 Old 11-28-2017, 08:58 AM Thread Starter
I changed it out and now I have my supplemental heater working again. Unfortunately the battery light is still on and my revs are still high. Leaning towards an alternator again. I'll have to rip them out of the truck now for load testing.
post #9 of 11 Old 11-28-2017, 01:11 PM
Quoted: 214 Post(s)
Garage
Keep us posted. I'm curious what you find wrong.
Sent from my XT1585 using Tapatalk
post #10 of 11 Old 11-28-2017, 01:21 PM
Heavy_GD's Avatar
Quoted: 3119 Post(s)
Garage
Feedback Score: 4 reviews
Sounds like corrosion or you have another issue and these symptoms are the result.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
