2014 f350 rear tail light wiring diagram - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 2Likes
  • 1 Post By Larry1013
LinkBack Thread Tools
Old 09-21-2017, 12:04 PM Thread Starter
I put led lights into my existing tail lights. Obviously have the hyper blinking. I got the resisters to install but need the wiring coloring to put them in correctly. Can Any one help out?
Old 09-21-2017, 05:43 PM
Quoted: 105 Post(s)
You can use FORScan to change this problem. It thinks your bulbs are burnt out. You need to turn off the lamp outage to the rear lamps.
https://docs.google.com/spreadsheets...AtI/edit#gid=0
HeavyAssault likes this.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
Old 09-21-2017, 05:50 PM
Quoted: 105 Post(s)
here are the wire colors.....
Larry
