Electric Viking V400 SS Horn Install Problem - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 1Likes
  • 1 Post By Larry1013
post #1 of 8 Old 09-06-2017, 02:08 PM Thread Starter
Maddog812's Avatar
I mounted a set of Viking Trumpet Horns on my 16 F350. Each horn has its own - and + wires. The instructions say I can wire the 2 pos together (same for the neg) then connect them to the factory horn plug. After doing so, only one trumpet worked. Double checked all wiring and same result. I than ran both wire direct to battery and they both worked. Retried the factory plug and only one worked. Factory plug puts out 12 volts. Any suggestions?
Maddog812 is offline
post #2 of 8 Old 09-07-2017, 01:50 AM
Quoted: 105 Post(s)
Get a relay to energize the horns with battery voltage. Use the truck horn plug to energize the relay.
The lights in this diagram will be the horns and the switch will be the horn plug. Pay attention to the numbers on the diagram and match your connections to the numbers on the relay you install.
Heavy_GD likes this.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is online now
post #3 of 8 Old 09-07-2017, 04:23 AM
Heavy_GD's Avatar
Quoted: 3121 Post(s)
Garage
Feedback Score: 4 reviews
agreed, you need more power!
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #4 of 8 Old 09-07-2017, 09:20 AM Thread Starter
Maddog812's Avatar
Thanks guy's for the quick response, on my way to the parts store.
post #5 of 8 Old 09-07-2017, 09:33 AM
ZMANN's Avatar
Quoted: 3910 Post(s)
get a pigtail for the relay it makes wiring easier
do a sound clip of those horns, please
I could never find electric trumpets that worked well on my boat I went with a small instant on compressor / dual trumpet setup
i suggest tipping the trumpets down and use the weather shield if they have them to keep moisture at bay ( if these are anything like standard electric trumpets)
6.0 flush pdf
ZMANN is offline
post #6 of 8 Old 09-08-2017, 11:05 AM Thread Starter
Maddog812's Avatar
Tried relay...
OK guy's, I bought a 12 volt / 30 amp relay and installed it as to your diagram and still only one trumpet sounds off. This weekend I will strip it down, test both horns again, and reinstall. Frustrating on something this simple. I really want to use the factory horn setup and not with a secondary horn button.
post #7 of 8 Old 09-08-2017, 11:30 AM Thread Starter
Maddog812's Avatar
Sound clips for Viking V-400 SS
Site won't let me post a clip, but you can see and hear it on amazon. search for viking v-400 ss, pull the page down to see video.
post #8 of 8 Old 09-12-2017, 01:51 PM Thread Starter
Maddog812's Avatar
Figured it out...
Well, after all of that, it turns out to be the horns, even though they came with rubber mounting gaskets the mounting bolts were grounding out the one horn. So I eliminated the steel bolts for nylon, eliminated the relay, and wired it directly to the factory worn wire and works like a charm. Thanks for a quick response and your help. 8 days on another site and 97 Looks and not one reply. You know where I'll be posting.
THANKS POWERSTROKE
The Following 2 Users Say Thank You to Maddog812 For This Useful Post:
ZMANN (09-12-2017)
