Aux 1 Upfitter OK for 300 Watt Light? - Page 2 - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 13Likes
post #11 of 20 Old 08-17-2017, 07:06 PM Thread Starter
swatdoc's Avatar
Quoted: 54 Post(s)
Garage
believe me I'm keeping the harness, and the first time this setup takes out a fuse I'll be re-wiring it your way
HeavyAssault and ZMANN like this.
swatdoc is offline
post #12 of 20 Old 08-18-2017, 03:09 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 822 Post(s)
Feedback Score: 3 reviews
If you use the extra harness think about using the #3 or #4 up-fitter. That way you have the 25A to use for something else in the future.
ZMANN likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #13 of 20 Old 08-18-2017, 04:02 PM Thread Starter
swatdoc's Avatar
Quoted: 54 Post(s)
Garage
Good idea HA - the lower amp switches would be just fine if only used to activate the harness relay
swatdoc is offline
post #14 of 20 Old 09-03-2017, 08:23 AM
Quoted: 2 Post(s)
I don't know about what you guys think but the output wires for AUX 1 and 2 seem really small for 25 amps.... I'm contemplating running a dedicated circuit for my compressor and using the lower amp aux switches for a relay because of the wire size directly out of the relay. Cant fathom running a 10ft lead @ 21 amp draw out of these tiny 25 amp factory ford leads for AUX 1 and 2 with the same size wire they have out. Any opinions?
PasadenaMike626 is offline
post #15 of 20 Old 09-03-2017, 08:40 AM
ZMANN's Avatar
Quoted: 3912 Post(s)
I use relays on most any switch / upfitter
there cheap and easy to replace I would rather wear those contacts and amp load the wire size i choose to run from the battery/ relay / equipment
6.0 flush pdf
ZMANN is offline
post #16 of 20 Old 09-03-2017, 09:25 AM
Quoted: 2 Post(s)
I hear ya. It would be nice to able to sufficiently run directly off the factory wires especially when they have a switch and relay integrated into the circuit already (one would think thats what they are intended for)... the wire size they chose for the 25 amp circuits is very disappointing... You would think they would give you a lead that was big enough to safely handle 25 amps @ 3% voltage drop at least the length of the truck.... Im just going to run my own power source with a marine grade fuse block and cable and switch the source with aux 4. little more work and money but well worth the time to prevent failure.
post #17 of 20 Old 09-03-2017, 10:36 AM
ZMANN's Avatar
even a weather proof like this is fine IMO
6.0 flush pdf
ZMANN is offline
post #18 of 20 Old 09-03-2017, 01:59 PM
N.S.D.Q.
Quoted: 822 Post(s)
So what gauge wire is rated to run 25A at 25'+/- ??
post #19 of 20 Old 09-03-2017, 04:24 PM
Quoted: 2 Post(s)
This chart works very well as a reference. I used it a lot when wiring my boat and when making a run. To answer your question- 25 amp draw at 25' run with 3% voltage drop you would want to run 6 AWG wire.
lowmpg likes this.
The Following User Says Thank You to PasadenaMike626 For This Useful Post:
livewr06 (11-29-2017)
post #20 of 20 Old 09-04-2017, 03:53 AM
lowmpg's Avatar
Quoted: 107 Post(s)
Since most of the thread is done, just wanted to add this for simple calculation of Watts/Amps...
Watts to amps (A) conversion calculator
The Resurrection
lowmpg is offline
