Pioneer NEX Radios - Page 8 - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 10Likes
post #71 of 90 Old 12-19-2018, 09:28 PM
Clearview's Avatar
Quoted: 2 Post(s)
Any insight on adapter cables to retain the factory navigtion and Sirius antennas with a avic 7201
Clearview is offline
post #72 of 90 Old 12-21-2018, 11:23 AM
Quoted: 11 Post(s)
Anybody know if a pioneer 2440 nex is able to be linked to a tuner and be able to function as far as changing tunes?
These are the two tuners i'm looking at edge 2 or EZ Lynk auto agent (which doesn't come with a screen) so this radio would serve as just that.
2013 f250 is what it would be going into.
Thanks
smt211 is offline
post #73 of 90 Old 12-21-2018, 07:29 PM
joebuck's Avatar
Quoted: 152 Post(s)
Thanks
No it will not work as a monitor
2012 F350 CCLB Lariat/ EZ Lynk Tyrant tuned/deleted/15+turbo swap/No limit stage 2 intake/H&S silicone CAC pipe/5Ē exhaust/2.5Ē BDS Leveling kit on 35s/Fox shocks/20Ē XD grenades
joebuck is offline
post #74 of 90 Old 05-19-2019, 11:38 AM
I tried installing a aftermarket stereo today and it will not power up.
I have a 2011 Lariat f250 6.7L.
Do I need to run any extra wires??
Does the factory Sub Amp need 5VDC to turn on or 12VDC??
It has factory SYNC and a factory subwoofer with factory ford amp.
Thanks for your help.
Sent from my iPhone using Tapatalk
tom.doyle.562 is offline
post #75 of 90 Old 05-19-2019, 12:23 PM
ZMANN's Avatar
Quoted: 3934 Post(s)
visit the 12volt .com site also
6.0 flush pdf
ZMANN is offline
post #76 of 90 Old 06-29-2019, 10:42 PM
Beach Bum
Jarrod B's Avatar
Quoted: 179 Post(s)
I just changed my stock radio to the maestro rr1 and used my nex2400 from my 6oh I just got rid of. but after reading this thread, im gonna unplug the sync and just use the radio for bt and phone. I was just trying to avoid the wiring up the pioneer mic into the roof.
what I noticed tho Is I don't have the same functions for sync besides basic bt with the pioneer. and also the metra radio dash kit sucks. I used spacers and longer screws to get it flush with the dash. might change it out for the scosche kit and see what that does.
2014 F250 CCSB 4wd
2004 Jetta TDI
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #77 of 90 Old 09-06-2019, 08:32 AM
Originally Posted by Ranger413 View Post
When wiring the radio to the truck, there is a reverse trigger wire as part of the harness. That will automatically switch the display to backup camera if one is plugged in and you have enabled it through the menu.
wish i was as handy as you! how was the whole process overall?
CindyW is offline
post #78 of 90 Old 09-10-2019, 09:57 AM
hey fairly new here, and not as handy as you guys! how long did it take you to complete it?
CindyW is offline
post #79 of 90 Old 10-07-2019, 05:28 AM Thread Starter
Quoted: 21 Post(s)
Months later and now I'm ready to pull the trigger.
Here's the short list . . . tell me what I may be missing.
Pioneer AVH4200 NEX
Pioneer microphone (to set equalizer for listening position)
Maestro RR
Maestro FO1 radio harness
Metra Double DIN mounting kit
Dual USB Port
Micro Bypass Parking Brake Switch
Using the "kit" above, I was able to get it installed in a couple of hours. At the same time I replaced the tailgate handle and added one that incorporated the backup camera. I used a $30 camera from Amazon to install into it. Comes on automatically when put into reverse and I can also view it on command. I've since added some Infinity speakers and have been enjoying life in the Super Duty.
The head unit is really nice. I wasn't able to get all of the gauges I wanted on it, but between a ScanGauge II and the NEX, I'm good to go. Pared with the Maestro RR, I get all of the hands free stuff I want. I don't use the SYNC at all.
Unlike some, I am happy with the Metra Double DIN mounting kit. It went in smoothly and looks as nice as I could hope for. The Maestro FO1 wiring harness allowed the install to go in without a hitch. Do yourself a favor and use the dual USB port for inputs. I replaced a 12v outlet on the passenger side for this purpose. Super slick.
Ranger413 is offline
post #80 of 90 Old 10-07-2019, 07:29 AM
Quoted: 40 Post(s)
Pioneer NEX Radios
Before you pull your stock head u it out, if it has sync be sure to go through the settings menu on it and disable Bluetooth. This will remove the annoying dialog from the maestro it receives from sync about no Bluetooth connection even if you are Bluetooth connected to the new head unit.
That whole kit is mostly plug and play. 2 hours top I think. Easy install.
The 4200 is a bit old now but works fine. I have it and wish I had a newer head unit with wireless CarPlay but it isnít required. Youíll like it and itís cheaper now Iím sure.
I agree about the 2 port usb like in the picture. Works great.
AMG1978 is offline
