Gauge mode question - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 9 Old 02-14-2017, 05:13 PM Thread Starter
Quoted: 2 Post(s)
Gauge mode question
My manual says I'm supposed to be able to view the status of the exhaust filter under gauge mode. I'm supposed to have 4 subcategories first oil and trans temp second compass 3rd exhaust filter status 4th blank. I only have 3 with the exhaust filter status missing. Before I take it to the dealer does anybody have any suggestions?
Sent from my SM-N920T using Tapatalk
jbusch10 is offline
post #2 of 9 Old 02-16-2017, 05:26 PM
Zak77's Avatar
Quoted: 7 Post(s)
I as well have only 3 areas. first being oil/trans, second compass and 3rd blank. I was hoping the 3rd might be used to add whatever i'd like to see.
Zak
2011 F250 Lariat CCSB PowerStroke. Bone Stock
Zak77 is offline
post #3 of 9 Old 02-16-2017, 05:27 PM Thread Starter
Quoted: 2 Post(s)
That's so strange when the manual says there should be 4 and the 3rd is the exhaust filter
jbusch10 is offline
The Following User Says Thank You to jbusch10 For This Useful Post:
JesseKK (02-16-2017)
post #4 of 9 Old 02-16-2017, 05:29 PM
Zak77's Avatar
Quoted: 7 Post(s)
Yup. I've found a few things misleading about the manual. I cannot figure out how to set the MyTemp so that the heater and heated seats turn on when started remotely.
I did find the exhaust fluid status in another menu though.
Zak
Zak77 is offline
post #5 of 9 Old 02-17-2017, 02:56 AM
Quoted: 105 Post(s)
What year and model is your truck?
If your truck is 2017, appears you can turn on the exhaust filter status screen. Starting on page 111 of the 2017 owner's manual, if shows you all the various settings and screens your Type 2 display can present to you. if you go to page 116, I believe the Exhaust Filter Status will turn on the Exhaust Filter screen. Try changing this under Display Mode and see if it shows up.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #6 of 9 Old 02-17-2017, 05:35 AM Thread Starter
Quoted: 2 Post(s)
Mines a 13
jbusch10 is offline
post #7 of 9 Old 02-17-2017, 05:57 AM
Quoted: 105 Post(s)
Mines a 13
You will need to use FORScan or have a dealer do it. Check the sticky threads General 6.7 Discussion.
General 6.7 Discussion (2011-2016) - Ford Powerstroke Diesel Forum
Larry
The Following User Says Thank You to Larry1013 For This Useful Post:
wchain (02-18-2017)
post #8 of 9 Old 11-06-2018, 10:45 AM
rogersbonntr's Avatar
Quoted: 29 Post(s)
Can you add Coolant Temp to Gauge Mode or is it only Oil/Trans (just those two available)?
What is the blank last screen for?
1997 F350 XLT CC SRW w/ 460 sold
2012 F350 Lariat CC SRW w/ 6.7
rogersbonntr is offline
post #9 of 9 Old 11-19-2018, 05:35 AM
MrTommy's Avatar
Quoted: 76 Post(s)
Garage
My 2016 is that way as well. Number three to the right is blank. I was wondering if this is just normal on all the trucks - or what. I first thought maybe Ford left it blank for a future software upgrade, but I know that's a pipe dream.
The compass is waste, in my opinion.
MrTommy is offline
