Recon Cab lights 2013 f250 xlt - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 9Likes
post #1 of 26 Old 02-14-2017, 01:35 PM Thread Starter
Brendon37's Avatar
Quoted: 3 Post(s)
I had my recon lights installed by a local shop but when i use the remote start feature my roof lights do not come on. i think they tapped into the wrong wire. What color wire are these lights supposed to be tapped in to? And sorry in advance if this question has been asked before but i have searched other threads and couldnt find the answer.
Brendon37 is offline
post #2 of 26 Old 02-14-2017, 02:38 PM
SixFive's Avatar
Quoted: 43 Post(s)
Garage
Hold up, you joined the forum 2 1/2 years ago and this was your first post?
ZMANN likes this.
2011 F250 Crew Cab 4x4 6.7 Lariat
SixFive is offline
post #3 of 26 Old 02-14-2017, 02:42 PM
mattastic13's Avatar
Quoted: 16 Post(s)
To be fair, when I am about to buy a vehicle, I join forums and start researching.
2012 F250 King Ranch 4x4
Ready Lift 1.5" level kit front/Custom 1" block rear/Fox 2.0s/Nitto Trail Graps 295/65/R20 on stock King Ranch rims No Limit delete pipe with Gearhead tunes on a SCTx4, EGR block off plates
No Limit Stage 2 Intake
Sweet Gipsy Danger Sticker
mattastic13 is offline
post #4 of 26 Old 02-14-2017, 03:06 PM
ZMANN's Avatar
Quoted: 3949 Post(s)
mattastic13 and SixFive like this.
6.0 flush pdf
ZMANN is offline
post #5 of 26 Old 02-14-2017, 03:11 PM
ZMANN's Avatar
this guys said purple wire outside back of light switch
6.0 flush pdf
ZMANN is offline
The Following 2 Users Say Thank You to ZMANN For This Useful Post:
Brendon37 (02-14-2017)
post #6 of 26 Old 02-14-2017, 03:11 PM Thread Starter
Brendon37's Avatar
Quoted: 3 Post(s)
anyone else wanna chime in or does anyone actually know the answer to my question???
post #7 of 26 Old 02-14-2017, 03:13 PM
ZMANN's Avatar
and this dude went to the pass kick
6.0 flush pdf
ZMANN is offline
post #8 of 26 Old 02-14-2017, 03:16 PM Thread Starter
Brendon37's Avatar
Quoted: 3 Post(s)
thanks for the replies zman ill check them out when i get home
post #9 of 26 Old 02-14-2017, 03:18 PM
ZMANN's Avatar
info from the wire guide at the 12 volt .com
2013 f 250
looks like the pass kick is the easiest
Parking Lights (-) yellow/orange - headlight switch, gray 10 pin plug, pin 2
May need to interrupt the headlight switch ground when triggering this wire. It is black/gray at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Parking Lights (+) yellow/blue + BCM in passenger kick, gray 10 pin plug (E), pin 6
6.0 flush pdf
ZMANN is offline
post #10 of 26 Old 02-14-2017, 03:21 PM
ZMANN's Avatar
SixFive likes this.
6.0 flush pdf
ZMANN is offline
