LED Headlights/Fog Lights - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 3Likes
post #1 of 16 Old 04-21-2016, 12:39 PM Thread Starter
Quoted: 52 Post(s)
Got these from eBay today and installed them...
This:
Stark LED 80W 8000LM 6000K 6K White 3-Sided Kit Dual Hi / Lo Bulbs - H13 9008
And this:
Stark LED 80W 8000LM 3 Sided Kit 6000K 6K White Fog Light H10 9140 9145 A | eBay
Note: I installed these lights to replace a full set of Philips Crystal Vision lights, that I had no issue with.
They are VERY BRIGHT. Especially the fog lights (probably due to no reflector) . Construction seems okay, 2 of the housings were loose out of the package so I tightened them. For some reason the wiring for the fog lights is backwards as compared to the connector, so I was able to just put the aftermarket connector in backwards to the OEM one. I then wrapped it in electrical tape to help hold it together. Just your run of the mill stuff when ordering goodies from across the Pacific pond.
They are slightly harder to install than a regular bulb replacement solely due to the larger bulb size (fan on the back) and the ballast. As always, it is so much easier to do if you remove the grille completely, which is very easy on these new trucks... I know some just loosen the top and pull it forward.
All in all, for the price, I don't think you can beat the brightness, of course for longevity, who knows...
When it's darker tonight I'll get some pics.
ROCKET VAPOR likes this.
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, Westin Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
The Following User Says Thank You to RUFFSTUFF For This Useful Post:
2016 Magnetic F250 (04-21-2016)
post #2 of 16 Old 04-21-2016, 04:16 PM
2016 Magnetic F250's Avatar
Quoted: 27 Post(s)
This:
And this:
I saw your post the other night about ordering these and I ordered the same ones from eBay as you posted. I had the same issue with the fog light connector polarity as you. I just installed mine after work today and they look nice. Pretty nice lights for the money. We shall see how they do in the dark. Thanks for the link
2016 Magnetic F250 is offline
post #3 of 16 Old 04-21-2016, 07:28 PM Thread Starter
Quoted: 52 Post(s)
Just got back from a baseball game and let me tell ya... These lights a seriously bright... probably illegal bright. Crazy thing is, the headlights and fogs are so bright, high beams end up being darker because the fogs turn off.
Note: The 1st picture is the only one with the lightbars on.
ID:	530162   Click image for larger version
ID:	530170   Click image for larger version
ID:	530178   Click image for larger version
post #4 of 16 Old 04-27-2016, 10:37 AM
ROCKET VAPOR's Avatar
Quoted: 19 Post(s)
@RUFFSTUFF I used your link to purchase the LED interior kit that you posted in another thread, and was very impressed with the results!
I plan to buy the LED head and fog lamps that you posted soon. Was there any modifications required to the truck (ie. lamp housing, brackets, wiring harness) to install these LED lights?
ROCKET VAPOR is offline
post #5 of 16 Old 04-27-2016, 10:50 AM Thread Starter
Quoted: 52 Post(s)
Good to hear! Those LEDs were straight plug and play. Let me say again... They are bright. I get people flashing their high beams at me quite often but that just means they see me... Right?
post #6 of 16 Old 04-29-2016, 02:56 PM
fdny136's Avatar
Quoted: 7 Post(s)
What link to interior leds?
fdny136 is offline
post #7 of 16 Old 04-29-2016, 03:33 PM
Quoted: 13 Post(s)
LEDs in stock reflector housings is not the smartest nor courteous way to go. If you want better lighting with out blinding other drivers go the projector w/hid route. Sorry hate to be that guy but it can be dangerous for other drivers
Castaway likes this.
cfiles is offline
post #8 of 16 Old 04-29-2016, 03:49 PM
thefarm352's Avatar
Quoted: 4 Post(s)
Do you think these would work in a 2013?...I know the site says only up to 2010 but I would think there isnt a different plug or set up with the 2010 vs a 2013.
thefarm352 is offline
post #9 of 16 Old 04-29-2016, 07:36 PM Thread Starter
Quoted: 52 Post(s)
Hate away. My dogs haven't said they don't like them so you're outnumbered 3 to 1.
ekimj57 (05-06-2016)
post #10 of 16 Old 04-29-2016, 07:38 PM Thread Starter
Quoted: 52 Post(s)
There isn't a difference. My 2010 is the same as 2015.
