pairing keypad - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
post #1 of 9 Old 04-15-2016, 01:11 AM Thread Starter
swatdoc's Avatar
Quoted: 54 Post(s)
Garage
pairing keypad
Hey guys I bought the oem keypad entry pad to mount on my driver's side door.
The instructions tell me how to enter my own passcode, but not how to pair the keypad to my truck. does anyone know how to do this?
I'm starting to suspect this might have to be done by the dealer with the IDS software?
If it does have to be done at the dealer, if they hook up the IDS, can they do things like this without flashing my pcm? My truck is deleted and I can't have them screwing that up
[SIGPIC][SIGPIC]
swatdoc is offline
post #2 of 9 Old 04-15-2016, 07:52 AM
JetExpress_6.7's Avatar
Quoted: 147 Post(s)
Garage
Should be able to do it just like you'd pair a second (or third) remote key fob. Google the sequence for that and try it out
Edit: here are the steps
1. Close all doors, then open your driver side door and press the Unlock button on the drivers door while it is open.
2. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. The door locks will lock and unlock to confirm that you have entered programming mode(Off is the position where you can remove your key, RUN is the position just shy of starting your car. If the door locks do not cycle you should try it again but faster. If they still do not cycle, your vehicle may not have keyless entry)
3. Within 8 seconds press any button on the first keyless remote to be programmed. Door locks will cycle to confirm programming. If you only have one remote then skip to step 5.
4. Within 8 seconds, press any button on the second keyless remote. Door locks will cycle again to confirm programming. Repeat step 4. for all other remotes.
5. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
2014 F250 "Jet Express" 6.7L CCLB, S&B Filter, Falken Wild Peaks, Walker Evans Legacy 18x9, Carli 2.5" Backcountry w/ Deavers, Iron Cross W2W steps, and more to come!
2003 F150 "2-wheel Peel" 4.2L V6 RCLB, My first truck, hand-me-down from my grandfather, bone stock
2000 F350 "Shop Truck" 7.3L V8 RCLB
JetExpress_6.7 is offline
The Following 2 Users Say Thank You to JetExpress_6.7 For This Useful Post:
swatdoc (04-15-2016)
post #3 of 9 Old 04-15-2016, 06:40 PM Thread Starter
swatdoc's Avatar
Quoted: 54 Post(s)
Garage
Thanks Jet I'll give that a try
[SIGPIC][SIGPIC]
swatdoc is offline
post #4 of 9 Old 04-21-2016, 10:49 PM
Quoted: 41 Post(s)
Did you get the OEM keypad (drilling required) or the Ford Accessories one (stick on)?
wchain is offline
post #5 of 9 Old 04-23-2016, 08:40 PM Thread Starter
swatdoc's Avatar
Quoted: 54 Post(s)
Garage
WC - I just got the stick-on keypad from Ford. Used jet's method and it worked perfect
[SIGPIC][SIGPIC]
swatdoc is offline
post #6 of 9 Old 04-23-2016, 09:00 PM
Quoted: 147 Post(s)
Garage
Awesome! Glad to hear it worked!!
post #7 of 9 Old 04-24-2016, 10:52 PM Thread Starter
swatdoc's Avatar
Quoted: 54 Post(s)
Garage
Yes - thanks again!
[SIGPIC][SIGPIC]
swatdoc is offline
post #8 of 9 Old 04-29-2016, 01:19 PM
Quoted: 105 Post(s)
After you enter the programming modes with the 8 key cycles, too program the keypad to the truck, you need to press 7/8 and 9/0 buttons to get the truck to recognize the keypad. these two buttons are the lock all doors buttons and it is easier to program the pad prior to mounting it.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #9 of 9 Old 04-30-2016, 05:11 PM Thread Starter
swatdoc's Avatar
Quoted: 54 Post(s)
Garage
exactly what I did Larry - just had it inside the cab with me.
[SIGPIC][SIGPIC]
swatdoc is offline
