Disable traction control and turn on locker at any speed - Page 3 - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 16Likes
post #21 of 37 Old 02-29-2016, 01:30 PM
Quoted: 167 Post(s)
Garage
Originally Posted by Mannysouza View Post
Haha, and why do I need to install a different diff? Do you think it matters if it is turning at 20 mph or 100 mph? By the way the Raptor has the same manufacturer for the ELD.
This mod is working amazing. Once you flip the switch you get a whole bunch of chimes and dings. I just tap the okay switch and they go away for a little while. The switch for the locker on the 4wd button doesn't work with this mod. also you have to turn off the switch to use 4lo. Just returned from San Felipe, Baja Mexico. We did about 500 miles of dirt and most at high speed. The total trip was about 3000 miles in all. Guess what, my rear end still works. How about that. Here is a shot of us doing about a 100 MPH.
Hey, Im not saying bad things will happen. Just want others to understand that not all may go as planned. In Fact you might want to put a disclaimer on yours. Its the world we live in Brother!
2011 Ford F-250 Super Duty Lariat
3.31 ELOD 4X4 6.7 Power stroke
01/24/2017 110,000 MI
S&B CAI
SCT X4 Tuner
Running a tow tune by AMDP
( on-demand exhaust brake from the AMDP tune).LED interior,LED AUX back-up,Westin HDX grill guard,High-idle,Aux 55 Gal Transfer tank,Draw-Tite Hide-A-Hitch gooseneck,LED puddle lights.4000x2 LED lights up front for dark country roads. Access Low profile bed cover.
Roof clearance lights.
mwe_060 is offline
post #22 of 37 Old 03-02-2016, 06:03 AM Thread Starter
Mannysouza's Avatar
Quoted: 126 Post(s)
I think you saying that "The diff will go tits up" put me in a corner. The reason ford disables it above a certain speed is todays driver rely on the nanny controls and if they have an uncontrolled circumstance they wouldn't be able to drive out of it. With the rear end locked the advancetrac would be unable to apply the brakes independently of each other and possibly causing an accident.
I totally forgot what a joke most drivers are. They all talk the talk but few walk the walk. I added some notes to the original post. Thanks for looking out for me.
I only did this mod because I almost killed myself and others in the dunes when my ABS allowed my brake peddle to go to the floor and turned off the brakes. It took about 200 feet for the truck to come to a stop. Scary to say the least.
HeavyAssault likes this.
High speed run in Baja Mexico
POST POLICE
Mannysouza is offline
post #23 of 37 Old 03-02-2016, 06:27 AM
Skyd Ram's Avatar
Quoted: 218 Post(s)
Yup,
I've been going back and forth between what locker to put in the back of my truck when I do a better gear ratio.
I'm wondering how all of the nanny's will act when I have something aggressive like a Detroit Locker or ARB air locker engaged. I'll surely have the ABS shut off fully whenever running the air locker so it may not be an issue.
I have also been put in some pretty scary situations when in sand or snow where the truck "decided for me" that it didn't need to have control of the braking.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | SOTA | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #24 of 37 Old 03-02-2016, 07:05 AM
Quoted: 34 Post(s)
what you guys think of this mod ??
SPE Full Lock Diff Kit 11-13 6.7L Ford Powerstroke
gunman41mag is offline
post #25 of 37 Old 03-02-2016, 07:46 AM
ASarsano's Avatar
Quoted: 31 Post(s)
Originally Posted by JetExpress_6.7 View Post
What pin connectors did you use for this? I think this might be the route I take since I don't have an ELD and I'd prefer not to mess with factory wiring (esp ones outside the protection of the cab). Could you take some pics maybe? Thanks in advance
hey sorry for the delay i got some pics this morning of it just need to upload em off my phone and post em when i get off duty tonight.
2011 F-250 FX4 Lariat CC SB
Flo-Pro 4" Race Pipe
No Limit Fab tunes
ASarsano is offline
post #26 of 37 Old 03-02-2016, 07:49 AM
ASarsano's Avatar
Quoted: 31 Post(s)
Hate it! First it disables your locker light like will get no notification when you lock on "some Trucks" ask me if should be designed to work on all not some.
then if you forget and leave it loced when you shut off ur truck it continues to feed electricty to the diff and will drain your battery over night
you need to manually shut off the diff when you shut off the truck
No Limit Fab tunes
ASarsano is offline
The Following User Says Thank You to ASarsano For This Useful Post:
gunman41mag (03-02-2016)
post #27 of 37 Old 03-02-2016, 02:43 PM
So if I do this mod I won't be able to switch in and out of 4wd? I'm thinking about making my switch the power for the locking differential so when I engage the e locker it will kill traction control I'm wondering if I'll be able to cycle between 4 high and 4 low. Or 2wd
Dthurst07 is offline
post #28 of 37 Old 03-02-2016, 05:17 PM Thread Starter
Mannysouza's Avatar
Quoted: 126 Post(s)
I found that I can easily go from 2hi to 4hi no matter how fast I was going. However when I went to shift in 4lo it wouldn't engage so I just flipped the outfitter switch off to my mod and put it in 4lo. Also the mod I did doesn't drain the battery when shut off.
Yes this was Dyzzles mod that I copied. Since there was no info about the mod I tried to document it for others to do the same.
POST POLICE
post #29 of 37 Old 03-03-2016, 05:28 AM
JetExpress_6.7's Avatar
Quoted: 147 Post(s)
Garage
Thanks bud. A simple description of the wiring might help too
2014 F250 "Jet Express" 6.7L CCLB, S&B Filter, Falken Wild Peaks, Walker Evans Legacy 18x9, Carli 2.5" Backcountry w/ Deavers, Iron Cross W2W steps, and more to come!
2003 F150 "2-wheel Peel" 4.2L V6 RCLB, My first truck, hand-me-down from my grandfather, bone stock
2000 F350 "Shop Truck" 7.3L V8 RCLB
JetExpress_6.7 is offline
post #30 of 37 Old 03-03-2016, 05:57 AM Thread Starter
Mannysouza's Avatar
Quoted: 126 Post(s)
Originally Posted by H&E View Post
Well done, glad this was easy for you to figure out, I'm still confused!
This wasn't easy but not difficult. Way easier now. Let know if you have any questions?
POST POLICE
