2013 rear view camera - Ford Powerstroke Diesel Forum
6.7 Electronics Discussion (2011-2016) 6.7 Electronics Discussion
 1Likes
  • 1 Post By WarChild
post #1 of 3 Old 09-02-2015, 12:25 AM Thread Starter
2 Power's Avatar
Anyone have the wiring diagram for 2013 up rear view camera tailgate wiring harness?
03 6.0, Studded, Deleted, Warren 155/30's, Powermax w/Single Plane Billet Wheel, Accufab Intake Elbow, S&B Intake, ZF6 w/ Valair Clutch, TSD SPD Tune
2 Power is offline
post #2 of 3 Old 09-02-2015, 02:59 AM
War is the answer!
WarChild's Avatar
Quoted: 29 Post(s)
Maybe in the 2013 super duty section...just sayin.
Heavy_GD likes this.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #3 of 3 Old 09-07-2015, 02:35 PM
This is the info I used when I hooked up an aftermarket camera in place of the original. It was from a discussion on one of these forums.
Quoted:
Here is how I hooked it up:
Red power wire of backup camera to violet/grey on harness
Ground power wire on camera to black/white on harness
yellow video wire on camera to white/green on harness
video ground wire on camera to brown/violet on harness
solid black wire on harness is not used.
This camera has the lines like the factory backup camera. Works great and is a nice addition to my truck camper for less than $50.
If anyone has any questions, let me know and I would be happy to help.
Gary, just look for a hardwired camera that is NTSC and you should be good to go. There are some others that ship directly from China that should work.
I also tried the above hookup, but there must be a harness wiring change on the 2013 Super Duty. There is no black/white wire on the harness so I am not sure which is the power ground. Will try to post photo of the camera end of the harness.
I figured out the power wiring for the 2013 F-350 camera. The camera end of the harness has 6 pins.
Pin 1 Violet/Grey +12V
Pin 2 Grey/Violet ????
Pin 3 Brown/Violet Video -
Pin 4 White/Green Video +
Pin 5 Black (not used)
Pin 6 Black -12V (grd)
2013 F450 Lariat
pvsaint is offline
