2014 F250 shakes like a jackhammer - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems (2011-2016) 6.7 Drivetrain Problems
 1Likes
  • 1 Post By Larry1013
post #1 of 5 Old 03-20-2019, 06:06 AM Thread Starter
Quoted: 7 Post(s)
I was coming into work this morning on the freeway when my truck started to ride a little stiffer than normal. About 30 miles later it was almost unbearable. It shook and girated so hard I thought the cab might fall off. I could see my lights in front of me shaking like a strobe off the cars I was following. I had to pull off the road because the steering started to get squirly. It ďjumpsĒ or shakes with every tire revolution it seems at low or high speed but the tires appear fine. I donít know what to make of it. Itís a 2014 with the fx4 package. Where do info from here?
Sent from my iPhone using Tapatalk
aheich86 is offline
post #2 of 5 Old 03-20-2019, 06:15 AM
Quoted: 105 Post(s)
Did it occur during a DPF regen?
Have you checked to see if any of the front end components are bad? Hubs, joins, driveshaft?
Has it occurred again or still happenings?
jman37 likes this.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 5 Old 03-20-2019, 06:47 AM Thread Starter
Quoted: 7 Post(s)
I do not believe so. It just shakes violently whenever the truck is moving. I just got to work so I havenít had a chance to check it yet.
aheich86 is offline
post #4 of 5 Old 03-20-2019, 09:59 AM
joebuck's Avatar
Quoted: 152 Post(s)
Death wobble possibly?
2012 F350 CCLB Lariat/ EZ Lynk Tyrant tuned/deleted/15+turbo swap/No limit stage 2 intake/H&S silicone CAC pipe/5Ē exhaust/2.5Ē BDS Leveling kit on 35s/Fox shocks/20Ē XD grenades
joebuck is offline
post #5 of 5 Old 03-23-2019, 05:39 PM Thread Starter
Quoted: 7 Post(s)
It was a bad tire. Rear right side tire separated and became egg shaped. Not good but better than a suspension or front end issue.
aheich86 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
looking at a 2014 6.7 f250 craigdvsn General 6.7 Discussion (2011-2016) 3 01-22-2018 12:01 PM
2014 F250 Running Hot While Towing Blue Steel 01 6.7 Problems Forum (2011-2016) 3 01-12-2018 06:04 AM
