Leaky seal? - Transfer case - Page 3 - Ford Powerstroke Diesel Forum
6.7 Drivetrain Problems (2011-2016) 6.7 Drivetrain Problems
 2Likes
post #21 of 29 Old 04-04-2018, 12:38 PM
voodooridr's Avatar
Quoted: 1055 Post(s)
That should be a 2wd tail shaft seal
Not discontinued, they have 3 of them at the Memphis warehouse
Sent from my XT1080 using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #22 of 29 Old 04-04-2018, 01:19 PM
Quoted: 3 Post(s)
Ah I see. Thanks for the clarification.
Black&Tan is offline
post #23 of 29 Old 04-10-2018, 09:11 AM
Quoted: 3 Post(s)
Since the internet doesn't seem to have a good picture of this seal, here it is. Installed it last night and everything appears to be good again. Thanks for all the help.
voodooridr likes this.
post #24 of 29 Old 02-28-2019, 06:38 AM
Where are the vents located please?
AZ Drifter is offline
post #25 of 29 Old 03-31-2019, 03:40 PM
PatMills57's Avatar
Been having this problem for a while now. Changed the rear seal and all was good for about a week then it started leaking again.. No visible damage to the seal itself. From what I can see the boot is seated properly but is still leaking. Anyone got any suggestions? Any help is greatly appreciated
PatMills57 is offline
post #26 of 29 Old 03-31-2019, 06:30 PM
That is exactly what's happening with me. Changed the seal and the leak started again after about a week or two. Flinging fluid on the underside of the body and leaving a slight spot on the floor. Pulled the driveshaft again and emery clothed the shaft and reassembled. So far so good, but still haven't found any vents. I've been here before. Anyone know where the vents are located?
post #27 of 29 Old 04-01-2019, 09:33 AM
Quoted: 3 Post(s)
Mine still leaks slightly also. Better than what it was. When I put the new seal in I also polished up the shaft surface pretty good. I thought maybe my case was slightly over filled. But I'm living with it for now...
post #28 of 29 Old 04-28-2019, 05:05 PM
PatMills57's Avatar
Anyone else have maybe have some insight? Still letting fluid fly over here lol
post #29 of 29 Old 04-28-2019, 05:51 PM
Quoted: 105 Post(s)
have any of you check the output shaft bushing? It might be too loose allowing too much driveshaft wobble for the seal to be effective? Just a thought. Might not be the problem.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
