HAS ANYONE SEEN THIS BEFORE - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-14-2019, 02:43 PM Thread Starter
Bought this 08 6.4 with 103k original miles and a fresh rebuild with only 3500 miles since and pulling our trailer it just shut down like the key was turned off. Found out later this happened and Joe's Engine that did the rebuild is trying to get an additional $3500 to do the replacement under the warranty. Is this common, everyone I have spoke with says they have never heard of a crank breaking, I was doing 60-65 2k rpm on a smooth straight section of the 5 fwy
Tom Zalabak is offline
post #2 of 4 Old 11-14-2019, 03:07 PM
ZMANN's Avatar
Quoted: 3962 Post(s)
you sure it did not hydrolock first ?
this Joes?
JOE'S ENGINES | 5200 S. Santa Fe Ave. | Vernon | CA | 90058
6.0 flush pdf
ZMANN is online now
post #3 of 4 Old 11-14-2019, 08:59 PM
RandomForumGuy's Avatar
Quoted: 214 Post(s)
Garage
Under stock power i have never seen a crank fail. If you bought the engine from them and its under warranty, why are they wanting to charge you?
RandomForumGuy is offline
post #4 of 4 Old 11-14-2019, 11:43 PM Thread Starter
Yes Joe's in Vernon, company truck was taken there for the motor to be rebuilt then back because of white smoke when started hot so they said they redid the heads and then less then 350 miles after getting it back the second time it blew up. Truck was running great, was on the 5 Freeway headed North east of Fresno on a smooth straight run following a Stillen Motorsports 18 wheeler for around 20 miles at 60-65 mph truck was running fine, wasn't pushing it, then as if I bumped the key off, nothing, no power steering or brakes, had to coast to the shoulder and luckily found some room off the road then the fun of trying to stop with a 34+ Trailer and no power brakes at 1:00 am.
As far as the charges they are trying to collect for new injectors, new oil cooler and $1000 labor complaining about having to cover the core damage cost and other costs.
Tags
6.4 , cause crank to break , crank breaking
