2008 6.4 no crank out of the blue f350 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-09-2019, 06:02 PM Thread Starter
Hi,
I have a 2008 f350 4x4 that I have owned for 3 years I have had a
spartan tuner on the 300 hp tune with no regen or egr system.
problem
I parked it in a my company's shop after a couple of days starting it
just to move a small trailer a few feet, one morning I go to start it
and had no cranking. I did hear a click on the passenger side fuse box
when the key is turned.
My diag
I checked the batteries and they were fine at 12.5v and cables were
tight I tested all fuse and swaped around the starter realy and fuel
pump relay, with the key on the on position I jumped that green wire
next to the passenger side battery and got strong cranking but no atemp
to fire up. I performed the same test on the actual starter terminals
and got the same results. I bought
the bluedevel obd2 tester and got
2 Powertrain Control Module Trouble Codes:
P0232: Fuel Pump Secondary Circuit High - Fuel Pump Secondary Circuit
High
P1000: On-Board Diagnostic (OBD) Systems Readiness Test Not Complete -
3 4X4 Control Module Trouble Codes:
P1832: Transmission Transfer Case (4WD) Solenoid circuit failure -
P1876: Transfer Case 2-Wheel Drive Solenoid Circuit Open Or Short To
Ground - Transfer Case 2-Wheel
Drive Solenoid Circuit Open Or Short To Ground
B1483: Brake On/Off Switch circuit failure - Brake On/Off Switch
circuit failure
When the key is turned to the on position I cant hear the fuel pump so I
thought not having the pickup pump pressure creates a no crank issue
but the ford dealer told me it should still crank with a busted fuel
pump. I checked the inertia switch and wasn't tripped. So i thought it
has to be an out of range egt sensor the Spartan tuner shower ambiant
temp and the with my mod6 tester it showed equal and ambiant temprature
on #1 and #2 egts. I know the is three so i performed a continuity test
on the the two EGT senders arround the cat and compared to a new one and
they all omh out the same.
I was wondering did I miss anything?
There was at one time a viper security system but it just had power
locks and a noise maker.
Hotchimichanga is offline
post #2 of 4 Old 11-12-2019, 04:10 PM Thread Starter
I broke down and took it into the dealer. its my first time taking it there.
post #3 of 4 Old 11-13-2019, 05:59 AM
Quoted: 88 Post(s)
Sorry nobody responded on here! I have no idea what it could be...but maybe the computer fried? That would at least explain when power is not getting sent out to anything (fuel pump, starter, etc)...but that's just a total guess by me.
onecrazyfoo4u is offline
post #4 of 4 Old Today, 05:30 PM Thread Starter
The ford dealer found fried pcm and a bad wireing harness
The Ford dealer after weeks of having the truck claim that the PCM was fried do to the harness having out of range resistance among various sending units. They want to replace PCM, harness, and batteries. I just gave them approval on the $3700 job.
Personalty I don't see how the PCM was fried do to the harness because wouldn't the PCM shutdown or throttle it's self if it got too hot. I hope my spartan tuner can work with the new pcm otherwise ill get an HP tuner.
